Wiring saw for 240V
   / Wiring saw for 240V #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
I decided to replace the original motor in the new for me Walker/Turner table saw. The original is only 1HP and 110V - I would like to go with at least 3HP and wire it for 240V.
The saw will be pretty much in the same spot, but I would like to be able to move it if necessary - it means wall plug and a cord and a switch.
I checked the local HD and must say I am confused. First of all, they have plugs for range and dryer and such - but which one would you use for a saw? I need 240V, not 110 - means three wires are enough, I don't have to bring the neutral over, but which plug and outlet to use?
Please, advice, how do you wire your 240 tools in your shop?
   / Wiring saw for 240V #2
Attached image for 220 volt configuration. The configuration may also depend on amps required?:)
Thank you, from what I could find, most people use L6-20R.
   / Wiring saw for 240V #4
For the air-compressor I used what I think is just the regular 6-20 plug and receptical. It is the one that looks almost like a 110v plug, except one of the flats is turned sideways, instead of them both being parallel. Those are good to 20A. And with a 3HP motor (which sounds like overkill) 20A should be fine.
For the welder I use the range/dryer style 50A plug
   / Wiring saw for 240V #5
Have you tried to use the existing motor? At the old woodworking website they claim the old Delta Unisaws with the low horsepower bullet motors have a lot more power than you would think for the rating. Maybe now they inflate the power rating of some motors.
   / Wiring saw for 240V #6
If I'm not mistaken, older motors were rated using the 'run' amperage, while newer ones rate using the start amps.
Perhaps that would explain the power differences.
But, yes, an older 1 hp will sure outperform a new import type 1 hp.
   / Wiring saw for 240V #7
Kinda slow but look at the receptacle for 220V on a generator.:)
   / Wiring saw for 240V #8
Will the saw arbor be able to handle the extra power and torque. If so this sounds like a good idea. I may convert my saw.
Thanks guys!
I am confident the saw can handle the additional power, it is good old American cast iron.
The current motor runs nicely but slows to stop under anything thicker than 1" - I believe it is bit tired. I am going to keep the original setup in storage - have to make new pulley - to be able to go back if necessary.
I found a Grizzly switch that will work nicely. I don't want to go crazy with this setup, but my former saw was just a $100 contractor's POS - I am ready for some real power and precision:thumbsup:
2014 Ford F-150 Ext. Cab 4x4 Pickup Truck (A55788)
2014 Ford F-150...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56129)
2020 FREIGHTLINER...
2015 International DuraStar 4300 Johnston VT651 8.5 Yard Street Sweeper Truck (A55788)
2015 International...
Utility Trailer (A52377)
Utility Trailer...
2019 Deere 316GR (A53314)
2019 Deere 316GR...
2016 KENWORTH T680 SLEEPER (A56129)
2016 KENWORTH T680...
