GaryM
Veteran Member
Many years ago when I installed my garage door opener, I ran Romex across the finished ceiling surface and installed an outlet box to plug in the opener cord. Now I know it wasn't up to code, but has worked fine for 30 years.
But we are planning to sell soon, so I know I need to make some changes. I have two thoughts:
1. Run EMT across the finished ceiling to the existing outlet box and replace the romex with individual wires.
or
2. Instead of EMT, use the surface mount raceway products that are available.
Number 2 would probably look a little nicer.
How should I transition from the romex to the wires inside the raceway or EMT. I need to do that inside a box of some type right. The romex currently runs inside the cavity of an unfinished exterior garage wall. I'll probably fasten a box to the stud at the ceiling height, bring the romex in one sidde and the raceway out the other.
Suggestions appreciated.
or
