Wiring problem
/ Wiring problem #1
Uncle Levi
Bronze Member
Maxbass, north Dakota
John Deere 2020
Does anyone know how to wire a Motorola TY26016 alternator or know where I can get a diagram ? Thanks.:confused:
/ Wiring problem #2
Two wires come from the output terminal. One goes to the starter solinoid (same terminal the batttery + is on). The second goes to circuit breaker then goes to the ignition switch "B" terminal.
The regulator terminal counter clockwise from the output terminal is not used.
The regulator terminal clockwise from the out put terminal goes to the ALT Indicator light and then from the same terminal of the ALT Indicator light it goes to the voltage regulator.
The field terminal goes to the voltage regulator
The ground terminal goes to the voltage regulator.
