Wiring Problem(s)
/ Wiring Problem(s)
Here's dielectric grease at princessauto.com. Noticed the Canadian
. eh
Thanks TTTTTT. Nearest princess auto is about an hour away.
Got some at nearby NAPA as I expected I would.
Not worth putting on their website i guess.
/ Wiring Problem(s)
Had a couple more hours to spare this weekend and decided to fully remove the lower dash to access the entire harness as I said I was going to.
I couldn't get the steering wheel off even with a puller (the jaws were too short to grab the metal and were just grabbing the rubber).
I cut a small part of the lower dash away to allow it to go over the steering column, and the cut out part isn't visible when reassembled with the upper dash panel.
I was able to clear away the big 'ol mouse nest (I knew had been there) and check for signs of chewing. None.
For some reason they put the fuse panel on the bottom right but ran the whole rear lighting harness along the left. Shook my head at that, but anyway.....
I checked for continuity from the right rear lights that "were" working. Good up to the fuse box, colors of wires change randomly, then on up to the switches.
Everything looked good. Showed continuity from back to the switch.
Used a test light and could see power to the switch, and as I operated the switch I had power to different wires, but still had no rear lights.
Checking along the harness there were no rubs or anything. Once I got to the connectors that come from the engine compartment through the cab I noticed things
flickering again as handled them.
Humid as hell today and two hours in my own soak I decided to use a small stabby tool and tweaked every blade connector I could and said that's enough. It's going
back together.
Routed harnesses, reassembled one of those and three of those and got the dash back together.
For a sense of closure I started 'er up and turned everything on.
Even the horn worked !!! Never did as long as I've known this machine (about 10 years). !!
Had low beam headlights but no high beam. That could easily be bulbs burned out. The previous owner fixed nothing on this thing as I said before.
Only thing not working is the left rear marker light, and that is the worst socket of the bunch for rust on the inside. I suspect a new socket will solve that.
I'm going to replace all the relays. One had a little green sweat at the terminal side of the casing but nothing inside. And during reassembly I put the original 3 pin flasher
back in which made a steady buzzing noise when 4ways were on, so I put the replacement 2 pin back in and 4 ways and signals worked fine.
Looks like my adventure may have ended.
Until the first time I move this thing, hit a bump, and it all goes out again :)
Final result, lots of loose connections. No other corrosion than mentioned before. And years of neglecting things which means I had no idea where I was starting from.
Could have been one connector causing it all, could have been more than one, could still be some burned out bulbs. Who knows.
/ Wiring Problem(s) #25
Nice job! Small wins are still wins. Use the dielectric grease on everything you know is working, hopefully no issues again in those parts.
/ Wiring Problem(s)
Will do.
I'd like to offer my services as the newest wiring expert on Foton tractors
but that is one thing that did NOT come from all this.
Now to see if I can take the doors off for the summer :) It's hot in that thing, and working amongst the trees with a door hanging open is a very bad idea.
I don't even need to try that to know it's a bad idea.
I thought maybe just pull the pins but they seem to be permanently in there and I've seen glass do some...... unexpected things when you tighten bolts going through it.
I've spent a total of 30 whole seconds looking at this.
Thanks all who offered ideas for my foray into Chinese wiring repairs.
Appreciate it.
/ Wiring Problem(s) #27
/ Wiring Problem(s)
A club I belong to was getting rid of a large travel/camper trailer for next to nothing. If it didn't sell we were scrapping it. I immediately thought of the roof a/c unit and was going to scoop it up if the trailer was going for scrap, but it sold almost instantly. Didn't even have a chance to measure it or see if I could even make it work for me.
Other than that, I still have to put some money in this tractor so an a/c unit is very low on my buy list.
/ Wiring Problem(s) #29
Yeah, it was just a thought.
/ Wiring Problem(s)
I'd love to have air. I'm in the bush and the mosquitoes are wicked. Worse some times of the year than others obviously, but always there.
Be nice to keep the doors shut.
/ Wiring Problem(s) #31
Not sure what your alternator output is, but you may have to upgrade if it's under 60 amps to accommodate the A/C. The nice thing about those roof mounted units is there is no compressor mounted on the engine, and no lines to run. They also take away the high humidity inside the cab.
2018 Caterpillar 289D Compact Track Loader Skid Steer (A59228)
2018 Caterpillar...
2010 Honda Accord Sedan (A59231)
2010 Honda Accord...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A61307)
Case Wheels for...
2012 Ford Transit Connect Cargo Van (A59230)
2012 Ford Transit...
CAT CB34 (A60462)
CAT CB34 (A60462)
2023 New Holland C327 Two Speed Compact Track Loader Skid Steer (A59228)
2023 New Holland...
