wiring on cluth safety swich
   / wiring on cluth safety swich #1
wbj459
farmtrac 300 dtc
I broke the wires on the clutch safety switch on my farmtrac 300 dtc . How do the 4 wires hook back up?
   / wiring on cluth safety swich #2
Can you match wire colors & splice 'em back up?
If not, you should be able to d/l a manual here.
Can't splice as they broke off at the safety switch
   / wiring on cluth safety swich #4
Many times on a 4 pole switch like this you'll find that 2 poles are normally open and 2 are normally closed. If yours is basically completing a ground circuit, I would think that you could do a couple of test hook ups until you found the right combination.
Thanks Tom , will do that Wayne
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A56859)
Year: 2016 Make...
Dorsey 4th Axle, Dual Axle, Air Brakes (A59076)
Dorsey 4th Axle...
LOT: Tap & Die Set, Hole Saw Set, Snap Ring Plier Set (A59076)
LOT: Tap & Die...
2015 Mitsubishi Outlander Sport Multipurpose Vehicle (MPV), VIN # 4A4AP3AU0FE026699 (A56859)
2015 Mitsubishi...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
PALLET OF JACKS AND JACK STANDS (A58214)
PALLET OF JACKS...
