wiring on cluth safety swich
   / wiring on cluth safety swich #1
wbj459
farmtrac 300 dtc
I broke the wires on the clutch safety switch on my farmtrac 300 dtc . How do the 4 wires hook back up?
   / wiring on cluth safety swich #2
Can you match wire colors & splice 'em back up?
If not, you should be able to d/l a manual here.
Can't splice as they broke off at the safety switch
   / wiring on cluth safety swich #4
Many times on a 4 pole switch like this you'll find that 2 poles are normally open and 2 are normally closed. If yours is basically completing a ground circuit, I would think that you could do a couple of test hook ups until you found the right combination.
Thanks Tom , will do that Wayne
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
1999 Ford RV , VIN # 3FCMF53S2XJA29020 (A51572)
1999 Ford RV , VIN...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
