Wiring in LED lights to my DK50
   / Wiring in LED lights to my DK50 #1
KanakaRick
Truckee, CA
KIoti DK50S
The front two work lights have black and yellow wires going to them (no problem) but the back two have a Black, a Yellow and a White with a red stripe. What is the white and red stripe wire? Can I ignore it and wire up the rear LED lights without using the white with red stripe? I would assume so, but want confirmation.
Thanks
   / Wiring in LED lights to my DK50 #2
All you need s the power and a ground wire. I can't say which colors you need but I wired my LED's on my NX4510 from my rear lights also just by testing the wires. I also added in a mini rocker switch on the back fender for the LED's.
   / Wiring in LED lights to my DK50 #3
I answered in your other thread about the third wire, it's more than likely a backup wire, turns them on when placed in reverse. So no you don't have to use it. Just take a test light and check for the hot wire when the switch is on. I don't remember the wire colors it's been a few weeks sense I worked on a DK light system.
Club Car Utility Cart (A55853)
Club Car Utility...
2015 CASE 621F WHEEL LOADER (A58216)
2015 CASE 621F...
2024 Superior Utility Trailer, VIN # 4M8EZ1426RD000880 (A57453)
2024 Superior...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
2015 JOHN DEERE 550K LGP CRAWLER DOZER (A52709)
2015 JOHN DEERE...
2025 GIYI GY-SZYMJ Hydraulic Stump Grinder Mini Skid Steer Attachment (A56857)
2025 GIYI GY-SZYMJ...
