Wiring diagram for MF 65 Gas model
   / Wiring diagram for MF 65 Gas model #1
MrEdHill
MG 65 Gas
Need the wiring diagram for a MF 65 gas model. The(Work Shop Service Manual) does not cover the gas model. When starting the engine dies as soon as the starter button is released. Please help.
   / Wiring diagram for MF 65 Gas model #2
Coil gets 12v from starter solenoid while starter is engaged and reduced volts from ignition switch after starter stops. Starting at coil,trace wire(s) back. If there's two wires on coil, one to solenoid and one to ballast resistor, the one on ristor is where problem lies. Make sure ignition switch is off, disconnect either wire from resistor then look for melted wire on resistor and check for continuity across resistor. Bad resistor is the most common cause of what you described but if previous test was good,trace wire from resistor back looking for broke or disconnected. When you reach switch,test for 12v with switch on. If still no joy post back. Questions?
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
9202 (A50322)
9202 (A50322)
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
2016 PETERBILT 579 (A52472)
2016 PETERBILT 579...
2024 JOHN DEERE FC 10 R LOT NUMBER 84 (A53084)
2024 JOHN DEERE FC...
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
