Wiring diagram for MF 65 Gas model
   / Wiring diagram for MF 65 Gas model #1
MrEdHill
MG 65 Gas
Need the wiring diagram for a MF 65 gas model. The(Work Shop Service Manual) does not cover the gas model. When starting the engine dies as soon as the starter button is released. Please help.
   / Wiring diagram for MF 65 Gas model #2
Coil gets 12v from starter solenoid while starter is engaged and reduced volts from ignition switch after starter stops. Starting at coil,trace wire(s) back. If there's two wires on coil, one to solenoid and one to ballast resistor, the one on ristor is where problem lies. Make sure ignition switch is off, disconnect either wire from resistor then look for melted wire on resistor and check for continuity across resistor. Bad resistor is the most common cause of what you described but if previous test was good,trace wire from resistor back looking for broke or disconnected. When you reach switch,test for 12v with switch on. If still no joy post back. Questions?
2017 Freightliner Cascadia 125 Single Axle Sleeper Cab Truck Tractor (A50323)
2017 Freightliner...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2015 FORD F-250XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-250XL...
2010 VOLVO ECR145CL EXCAVATOR (A50854)
2010 VOLVO...
PAIR OF 29 FT PIPE RACKS (A50854)
PAIR OF 29 FT PIPE...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
