wiring diagram for a 1961 massey ferguson 50
   / wiring diagram for a 1961 massey ferguson 50 #1
MF1135
North Vernon,IN
MF1135,MF50
looking for a wiring diagram for a 1961 massey ferguson 50 three cylinder diesle someone put a alternator off of a GM truck and messed up the wiring.and how much boost can you push with a turbo without working on that engine.
   / wiring diagram for a 1961 massey ferguson 50 #2
You may find that someone has installed a one wire type charging system. What makes you think that this is a problem? Check the output first with a multimeter and see if the battery is recieving a charge.
its a two wire alternator off a chevy we need to rewire the tractor
   / wiring diagram for a 1961 massey ferguson 50 #4
Sure need a wiring diagram for a MF 50 gasoline Perkins engine. Thanks. Mike
   / wiring diagram for a 1961 massey ferguson 50 #5
If it has a two wire plug and a heavy wire single connection point it's concidered a three wire alt. On the plug would be marked sense and field.
Kubota B7800 4x4 Tractor (A51573)
Kubota B7800 4x4...
Ryobi Sliding Compound Miter Saw (A51573)
Ryobi Sliding...
THRESHOLD 30" SQUARE OUTDOOR GAS FIRE TABLE (A51248)
THRESHOLD 30"...
2009 International Frazer Bilt X-514 Ambulance (A52377)
2009 International...
2021 Ram 1500 Bighorn (A53472)
2021 Ram 1500...
