Wires under seat are for what?
   / Wires under seat are for what? #1
chucko
Veteran Member
Polk Co , Fl
bx1800
If you flip up the seat were the wires are right in the area of the little red vent on the trans case is several wires that are pluged to nothing. What are they ment for?
I might be able to take a pic tonight if needed
   / Wires under seat are for what? #2
They are there for adding auxilary lighting. Many of us have added fuse, and switch (relay/switch in some cases) for our auxilary lights.
   / Wires under seat are for what? #3
I believe only one of those red wires is for auxiliary lighting/accessories. I think the other one is for a hydrostatic transmission temperature sensor (which US BX's appparently don't have). I've tried to hook lights to it, but it doesn't carry enough power, and all it does it trigger the "HST" lamp on the dash.
do you know i is is hot all the time or just hot when the headlights are on?
   / Wires under seat are for what? #5
</font><font color="blue" class="small">( I believe only one of those red wires is for auxiliary lighting/accessories. I think the other one is for a hydrostatic transmission temperature sensor (which US BX's appparently don't have). I've tried to hook lights to it, but it doesn't carry enough power, and all it does it trigger the "HST" lamp on the dash. )</font>
Do you know where the temperature switch mounts and what tractors use it? Is it possible to make it operational??? thanks..
   / Wires under seat are for what? #6
I have to echo Junkmans question . And does it apply to the L series tractor ?? Seems like a handy thing to monitor . John
   / Wires under seat are for what? #7
The aux feed is independent of the headlight circuit. It is only hot when the ignition is on.
   / Wires under seat are for what? #8
Okay, Cerberus and Junkman, now I'm gonna pull a Sergeant Schultz ("I know nothing, I see nothing ...").
All I know is that was the info I got in response to one of my previous threads here .
   / Wires under seat are for what? #9
</font><font color="blue" class="small">( Okay, Cerberus and Junkman, now I'm gonna pull a Sergeant Schultz ("I know nothing, I see nothing ...").
All I know is that was the info I got in response to one of my previous threads here . )</font>
I asked the same question back then in that other thread and didn't get a reply either. If I ask enough times, hopefully someone will come up with an answer? I think that I am going to examine the hydro for possible locations that might accept a temperature switch and go from there. Does anyone have a factory shop manual that might give the location or any more information? Possibly Art could look this up in one of his parts books or check with the factory representative when he visits next time???? Inquiring minds
need
to know!!!!! /forums/images/graemlins/wink.gif
Bomag BW 211D-3 (A47477)
Bomag BW 211D-3...
2011 Liebherr L586 Wheel Loader (A53473)
2011 Liebherr L586...
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A53473)
2015 RAM 5500...
LINDE WELDER (A53843)
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
