Wire welder torch connect, + or - ??
   / Wire welder torch connect, + or - ?? #1
SSdoxie
Elite Member
Cumberland Plateau, TN
Bobcat CT225
I have 120V 125 amp wire welder, mig capable. It says to hook up torch to negative with flux core wire and to positive for solid wire. What is the defference? Does one give hotter arc versus the other? I have always used with flux core because I am either welding outdoors or with shop door wide open.
   / Wire welder torch connect, + or - ?? #2
I am going to wade in here and get blasted out. I have a 240V AC stick machine. But I do know of the rods NOT to run. When on DC stick rods are marked as to the correct polarity for the charertics to make a good penetration.
When your manufacture says to change the polarity about for solid or flux wire it is to have more heat in the wire or base.
Craig Clayton
   / Wire welder torch connect, + or - ?? #3
Miller - Successfully Welding Sheet Metal With MIG And TIG
Electrode Polarity
For welding with solid wires, use electrode positive or "reverse" polarity. While EP directs more heat into the base metal than electrode negative (EN or "straight" polarity), you will obtain the best results with EP and following the guidelines provided here. If you've been using flux cored wire, be sure to change your machine's polarity from EN to EP.
Read your WIRE makers directions for flux core polarity if using specialty wire:
Why does flux core MIG require negative polarity? - Yahoo! Answers
2014 Ford C-Max Energi Hybrid Hatchback (A48082)
2014 Ford C-Max...
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A49346)
2020 John Deere...
2012 Chevrolet Silverado 1500 LTZ Crew Cab Pickup Truck (A48081)
2012 Chevrolet...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
2014 International DuraStar 4300 26ft Box Truck (A48081)
2014 International...
2019 CATERPILLAR 440 BACKHOE (A51242)
2019 CATERPILLAR...
