Wire Welder Question
   / Wire Welder Question #1
ALHILLDIRT
Bronze Member
ALABAMA
Kubota GL3240
I needed a quick repair and the only wire I had left at the time had some light rust spots. Big mistake, now I apparently have some of this on the inside of my cable liner, because I'm getting uneven feed on the wire. Any recommendations on cleaning the liner, or am I out the cost of a new liner.
   / Wire Welder Question #2
You can try blowing it out with air...
   / Wire Welder Question #3
Did you try cleaning the wire feed wheel or adding pressure on it?
Is the wire kinked? Is there still a tad bit of slag blocking or pinching the hole in the tip?
I doubt the liner is the problem.
edit: Is the wire in the right grooves on the feed wheel, and is the new wire the right size for the grooves?
   / Wire Welder Question #4
You didn't mention whether it is plain wire with gas or flux core.
Every once in a while I run into feed issues with flux core due to variations in diameter. With .035" cored wire, I now use .040" or .045" tips which solves most of that problem. Also flux core should be fed with a serrated wheel which helps resolve varying diameter wire.
Also doubt if "dirty" liner is an issue. If suggestions so far don't help, please give more details.
Sherweld
   / Wire Welder Question #5
I run little cleaning and lubing pads on the wire just before the feed rollers
   / Wire Welder Question #6
I used to work in a welding shop we would remove the liner and fill an oil pump can with a powerfull solvent. put a little rubber hose on the end of the pump can nozzle and attach to the liner. pump a bunch through then blow out with air. I think it was MEK, methlye ethlye ketone, dont remember for sure i think it causes brain damage maybee just get a new liner.
   / Wire Welder Question #7
I agree, the problem is usually the feed wheel. The wire pretty much fills the liner unless it has a tremendous amount of wear in it.
Sherweld
Sorry for the lack of info. I'm using .035 flux core most of the time. Top feed roller is serrated, bottom roller is set for the correct groove. Don't remember on the tip, but I didn't have feed problems until I used the rusty wire. I even removed the tip, flipped the feed roller up, and had difficulty pulling the wire through. Finally went to new wire and managed to get it to feed better after hand pulling a lot of wire through, but using the feed rollers it's still jerky. Have tried blowing compressed air through it. Anyone know what type of lubricant I could use that might help. It just seems like there is more drag on the wire going through the cable than there was before.
   / Wire Welder Question #9
I guess I am odd man out here, but if you ran dirty wire, I would tell you to pitch the liner, new tip, pull the rollers and clean them well with a stainless brush and solvent (assuming Steel rollers, I don't see which welder you have)
I have never seen a reccomended lube for the wire, and would not use one.
I don't remember what my last liner cost, but I think it was under $10 for my 15' miller gun.
I hate it when wire goes bad, and it slays me too throw it out, but, every time I try and "save" one I regret it.
   / Wire Welder Question #10
Okay .... I have to confess that I once tried WD40 when I was struggling with feed issues (before tip change)
It made a very noticeable improvement.
I was careful to do quite a bit of non-critical welding until I felt that most of the WD40 was gone.
Sherweld
2008 Ford F-250 Knapheide Service Truck (A50323)
2008 Ford F-250...
2012 KENWORTH T800 DAYCAB (INOPERABLE) (A50854)
2012 KENWORTH T800...
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
2010 Triple B Gooseneck Inclosed Car Trailer (A50514)
2010 Triple B...
2004 Big Tex 10PI 18ft T/A Pipe Top Utility Trailer (A49461)
2004 Big Tex 10PI...
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A51039)
DeeZee Crossover...
