Wire tie, sisal twine or poly twine?
   / Wire tie, sisal twine or poly twine? #1
mandysong
Bellevue, Washington
JOHN DEERE 4240S
Have you ever questioned which kind of twine is better, wire, sisal or poly twine? I always use poly twine while some of my neighbors and friends use the remaining two, so I just collect some perspectives from them. Here I want to share my view on these three common twines with you.
Like every coin has two sides in the reality, each of the three twines has advantages and disadvantages. First of all, I will talk about wire. The biggest advantage of wire tie is that it makes the bale considerably tight. With the metal tie, the baler could make the bales much more dense, while under the same pressure sisal and poly twines would break. When bale straw, one of my neighbors is always prefer wire tie. Though it is more expensive than the two remaining twines, hay bale snap during transportation is more terrible. Choice of my neighbor tell us the significant drawback of wire tie. It is expensive. For people who would do the math when calculate hay yield and profit, he may choose poly or sisal twine, especially if his bales are small squares. My neighbor told me that price for metal wire has rised recently, but poly twine is remaining steady. Another disadvantage of wire is that it may damage us when we operate improperly since the metal tie is very hard and sharp.
When baler is first invented, sisal was used in making bales. Compared with poly twines, sisal has an obvious advantage that it is 100% biodegradeble and sustainable. When poly twines are left in the farm and cattles eat them mistakenly, often does, these nonbiodegradable twines will kill cattles. Sisal twines just rot away in the farmland and field. Rotted readily brings the disadvantage of it, that it would break easily during baling and transporting. When hay is baled with sisal twine, transportation and storage loss are high. As a kind of plant fiber, sisal twine is that it would be chewed by rodents, such as mice. That could be a threat for the storage.
Honestly, I have a preference that poly twine is the best in the three twines. My reason is really simple, I always use it and never have a problem with it. In spite of this, I still list the advantage and disadvantage of poly twine. Poly twine is lighter and softer than wire, so it is easier on hands. It does not damage the tool or person if operate mistakenly. it is cheaper. Cheaper than wire and stronger than sisal twine, taken together, poly twine is a better choice. But under high pressure, poly twine my break while wire is still workable. So for big square and straw, some people will choose wire twines. It's important to notice that poly twines are created with different grades. Choose the suitable one could help us save cost and effectively tighten a bale. My preference is T&H baler twine. To bale straw and big square, I use 650 of it instead of wire. It is cheaper and bale the straw tightly. I have used it for two years and never have a problem.
Looking at both short and good sides, poly twine is a better choice. That is just my view. We need to find the right twine based on specific requirement. DO you have any experience and suggestions on his matter?
   / Wire tie, sisal twine or poly twine? #2
You summarized the pros and cons very nicely. Personally, I have never seen I bale tied with wire (I guess I am too young). My old square baler (New Holland Model 68) only works with sisal- so that's what I use. The baler does fail to knot the sisal properly if I try to make the bales too tight.
For my round baler (Vermeer 605 super M) I am also a fan of sisal- mainly because it is biodegradable and doesn't have to be removed when I drop the bales into the feeders. The poly net wrap is a little cheaper (and more popular), but can be a real pain to remove especially when the bales are ice covered.
UNUSED RAYTREE RMBD72-72" DRUM MULCHER (A51248)
UNUSED RAYTREE...
2013 FORD F-150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F-150 XL...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2020 JOHN DEERE 333G SKID STEER (A51246)
2020 JOHN DEERE...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
2014 MACK GU713 WATER TRUCK (A51247)
2014 MACK GU713...
