Wire loom for LED lights - recommendations?
   / Wire loom for LED lights - recommendations? #11
"normal" loom is all over in the engine compartment.
   / Wire loom for LED lights - recommendations? #12
I buy mine in big rolls from McMaster, but my local farm store sells 14-2 black extension cord in bulk.
McMaster-Carr
Click on "corrugated" on top and then "polyethylene" at the bottom to filter the results.
   / Wire loom for LED lights - recommendations? #13
When I dont want the aggravation of the split loom opening up or having to tape it and years later finding the tape coming off, I resort to this product from Home Depot.
It is not split so you have to fish the wires but it is tough. Electrical supply places may have it in longer lengths.
Carlon | ENT Nonmettallic Conduit – 1/2 In | Home Depot Canada
Dave M7040
   / Wire loom for LED lights - recommendations? #14
Slang term for ENT is "Smurf Tube"
   / Wire loom for LED lights - recommendations? #15
Why 14 gauge wire for a set of LED lights? Or better yet, why not run a single heavy power cable, like 10 gauge,and use some relays to switch your lights? Smurf tube is rated for hot areas, I think. **** for stout!
   / Wire loom for LED lights - recommendations? #16
NAPA Auto parts sells split wire loom by the foot.
I second that... and get yourself some decent black electrical tape and call it good.
   / Wire loom for LED lights - recommendations? #17
Try the local electrical supply house. You should be able to find some plenum rated cable if you need a high temp rating.
Plenum rating just means it's low smoke and the fumes won't kill you if it does catch fire.
   / Wire loom for LED lights - recommendations? #18
Don't use electrical tape all over. I saw someone on here who thought they were doing a good job wrapping the ENTIRE harness using 3M Super 33 or Super 88. Both are great electrical tapes and my preferred choice.
However, they are not for looms. They make a sticky gooey mess. Use a quality wiring harness tape.
Personally, rather than split loom I usually use either PET braided sleeving with heat shrink on the ends if I have individual wires, or a sheathed cable if not. The PET does a good job of protecting the wires, however it is not sealed and dirt/water can get to the wires and makes it look a bit dirty.
   / Wire loom for LED lights - recommendations? #20
I use the split loom from Harbor Freight. I've never had a problem with it melting in an engine compartment. Just don't run it over the top of your exhaust manifold. Just used some 3/8" this morning while replacing a window motor. It's good stuff and cheap.
You don't need high-temp unless you're running it next to the engine block. Anywhere else is unnecessary unless your engine is on fire but you'll have bigger problems than melted loom. :)
I also use a thick cotton braided loom for antique cars. It looks just like the rear looms used on my Ford 3910 except it's black.
2013 Ford F-150 Ext. Cab Pickup Truck (A55852)
2013 Ford F-150...
(6) 8 LUG FORD DUALLY WHEELS & TIRES (A57192)
(6) 8 LUG FORD...
2016 International WorkStar 7400 21ft Cylinder Pallet Flatbed Truck (A55852)
2016 International...
2005 Dodge Ram 4x4 Crew Cab Pickup Truck (A55852)
2005 Dodge Ram 4x4...
FORD 8530 TRACTOR (A57192)
FORD 8530 TRACTOR...
2024 78in Hydraulic Brush Grapple Skid Steer Attachment (A55851)
2024 78in...
