Winterizing my K
/ Winterizing my K #1
wjoerob
Franklin IN
Kubota 6100
Can someone please help out us newbies by telling us how to prepare our Kubota tractors for winter? I plan to use my 6100DT for moving a little snow, but otherwise it will be sitting idle a lot. Change the oil? Fuel additives? Any other suggestions?
Thanks for your input.:)
/ Winterizing my K #5
Drive it around once a week or at least start it and do nothing other than normal PM.
/ Winterizing my K #6
Mine may sit for weeks at time over winter too.
I wondered if anyone bothers to position all pistons so they are collapsed to minimize the chrome cyclinder from exposure and no need to spray them with anything. I thought this might make the seals last longer.
On the BX24 you can position pretty much everything so no chrome is exposed. I wasn't sure though if it's bad to keep the Hoe under hydraulic load to accomplish this?
/ Winterizing my K #7
This year's winterization routine goes like this:
Drop the fertilizer spreader, put on the rear blade.
Change oil & filter.
Replace radiator screen with piece of cardboard having a 6" dia hole in center.
Keep fuel level as low as possible. (I can already hear people picking up rocks to throw at me.)
Replace fuel filter to get any water out of system and minimize chances of gelling.
Keep indoors in unheated building.
Plug in block heater at temps in the teens or below.
Ordinarily I would check anti freeze but it was changed last year so I won't bother.
/ Winterizing my K #8
2021 BOBCAT E50 EXCAVATOR (A63276)
2021 BOBCAT E50...
1998 INTERNATIONAL 2674 6X4 T/A VACUUM TRUCK (A66091)
1998 INTERNATIONAL...
Hay Feeder (A65640)
Hay Feeder (A65640)
Case 1083 20ft Corn Head (A63118)
Case 1083 20ft...
John Deere Mower Model LT155 (A62679)
John Deere Mower...
2016 Boxer 700HDX Compact Skid Steer (A63109)
2016 Boxer 700HDX...
