Winter weights for a pickup
/ Winter weights for a pickup #21
I had a F-150 Lightning and it sucked in the snow. I filled the bed with snow and all it did was make it heavier to push. In all honesty I think the tires make all the difference. Bad tires and all the weight in the world=stuck.
Chris
I've owned nothing but pick up trucks since 1989.
The were
1* 79 Datsun
2* 83 Dodge D-50
3* 86 Dodge D-50
4* 89 Dodge D-50
5* 89 Nissan
6* 92 Toyota
I still have trucks 3 5 & 6.
All 6 were 2 wheel drive.
Never carried sand bags or other extra weight in the bed of any of them.
Never had traction or handling problems on ice or snow.
L . B .
/ Winter weights for a pickup #22
My dad used to go down and dig out a big wash tub of river sand (cost = free) then spread it out in the basement to dry (cost = free). Then he would put the sand into empty gallon milk jugs (cost = free). They went in the truck. Winter weight for better pushing and ready to spread on ice when needed. (cost = free)
Did I mention that the old guys used to like to save a nickle here and there?
jb
/ Winter weights for a pickup #24
agree with previous post. that is what i don't like about the tires filled with cement idea - dangerous and no easy way to secure that i can see.
the reason the bladders full of water are popular is they are low center of gravity and easy to fold up during warmer months. but they are a tad pricey.
i like the bed full of snow idea. melts when the weather warms up and never even know it was there.
also agree 100% that nothing is more important than good tires. i run dedicated winter tires all around and they make a world of difference.
a limited slip rear diff can also be helpful in certain circumstances to avoid using 4x4.
amp
/ Winter weights for a pickup #25
I have been trying to think of a winter weight that can be properly secured in the back of my F-150.
I don't even like the bag of water idea, not because of bursting when it freezes (just don't overfill it) but because of the issue of it coming forward in a accident and potentially entering the cab. I bet 400 lb of ice hitting you in the back of the head can screw up your brains no end.
Maybe 4 WD and good winter tires are the solution I am looking for.
OTOH, concrete-filled tires can be secured by a chain through the middle attached to the tie-downs in the rear corners of the bed. When I get the winter tires, the old ones will be available for filling with concrete.
/ Winter weights for a pickup #26
CurlyDave and Ampsucker are right on, you don't want tires filled with cement sitting in your bed.
If your in an accident they may not go thru your cab and get you, but they very well may roll down the road and hit someone else.
What ever you put in the bed if it's got any weight to it you better have it secured really tight.
Good tires will make a difference, but about 350 to 400 lbs in the bed can really do wonders, summer or winter.
/ Winter weights for a pickup #27
The were
1* 79 Datsun
2* 83 Dodge D-50
3* 86 Dodge D-50
4* 89 Dodge D-50
5* 89 Nissan
6* 92 Toyota
L . B .
You should come up here. You wouldn't even make it out of my driveway with any of those trucks. A 2WD truck is a nice practical vehicle that gets great gas mileage compared to the same model with 4WD though.
/ Winter weights for a pickup #29
Anytime we have snow or bad weather and I need weight for traction I just use my FEL and put a couple of bucket loads of snow at the rear of the truck. I have all the weight I want and when the weather is better I don't have to worry about getting it out. It goes away all on it's own. Besides, this method doesn't require anything to keep the weight from moving around and damaging your bed. My grandfather and a friend of my dad have been using that method since the 40's without ever having any issue. It works great for me as well. Besides, I can't think of any method that is more cost effective. ;)
/ Winter weights for a pickup #30
The only P/U I have driven in limited traction conditions that would basically move out of it's own way in two wheel drive configuration has had weight in the box.:D
My present truck is a basic "Road Ornament" in limited traction conditions unless the four wheel drive is engaged.:D
/ Winter weights for a pickup #31
The were
1* 79 Datsun
2* 83 Dodge D-50
3* 86 Dodge D-50
4* 89 Dodge D-50
5* 89 Nissan
6* 92 Toyota
L . B .
Those aren't trucks! They are about equal to using an El Camino or something. If you add any weight to their beds, their overloaded. Those are just cars with a large open trunk.
/ Winter weights for a pickup #32
I drive a '99 Dodge king cab long box w/2wd, it's a work truck and always full of tools under the topper (at least 500#'s) on a shelf behind the cab. The bed is always in flux, with larger tools and materials going in and out but in the winter I always try to have at least two bags of ice melt (dual purpose :) ) behind the wheel wells. Good tires or not that extra weight makes a big difference. As far as "securing the load" goes, well, everything is relative :rolleyes:
/ Winter weights for a pickup #33
I've seen more than a few folks do that, but my issue is that I need the truck a few times a month to actually haul something, and a bed full of snow can create a useful space issue...
/ Winter weights for a pickup #34
Two drums laying between the wheel wells, old tires for a rubber bumper, straps over the drums. Fill with water for weight, pull the bung to drain next spring. JC
/ Winter weights for a pickup #35
Tires filled with cement sounds like a lot of work -- Old feedbags full of sand -- if you get stuck you shovel sand out of the feedbags as a traction aid. If they freeze to the bed, so much the better. Have been in accidents and they never came out of the bed (lots of other things have though:eek::eek:) Probably the only thing worse than an empty pickup for traction on ice and snow is an old Camaro. Tires help but still need a little weight is a necessary addition. I have driven and gotten stuck in pick-ups all my life (two wheel and four wheel) and anyone who thinks that just putting it in four wheel drive will solve the inherent traction problem should probably plan to stay in warmer climes:p -- JMHO
/ Winter weights for a pickup #36
I think what it comes down to is everyone needs a nice, hot wife, a truck, heavy tractor and trailer, and tow it around all winter! The tongue weight would be great! Then when you get really stuck, you can unload the tractor, have the wife get on and push/pull you out of the snow!
How's that?
Kyle
/ Winter weights for a pickup #40
Kyle,
Aren't you supposed to be in school? LOL. How do you know to make wife kokes so early in life.
Thanksgiving week.
A country boy hangs around the older guys many times! I learn! I'm young, but am very quick witted b/c of hangin around guys young and old.
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
2016 Ford Explorer (A59231)
2016 Ford Explorer...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
7'' PALLET FORK EXTENSIONS (A61572)
7'' PALLET FORK...
2019 Ford F-350 4x4 Crew Cab Pickup Truck (A61568)
2019 Ford F-350...
Utility Cart (A59231)
