winter tires
   / winter tires #1
mike123
Bronze Member
Saskatchewan,Canada
Toolcat B 2004
I went a tire shop today to get the LT 235 75 15 in a michelin ice latitude. The most knowledgeable guy told me there is no way those tires or any other winter tire in a 15 inch is going to take that load?
He said I must move in to a 16 inch and 10 ply.
Anyone have any suggestions what to do?
Thanks Mike
   / winter tires #2
Take what load??? Im lost, dazed, and confused..
Brian
   / winter tires #4
the weight of the toolcat 8000 lbs
8000#...Really?..... Last year I used LT235/75-15's and I put them back on for this coming year just yesterday. I'm carrying about 700# of ballast and a 800# blower and I've not had problems. The single max loading for these 6-ply tires I'm using is 2000# apiece.
Having said that, if I were to do it all over again I would go to LT225/75-16 (Load Range E/10-ply) tires just for added margin. I would purchase 16" trailer wheels (6 on 5.5" bolt pattern...one of the most common) to save some $$$. Go to the trailer parts store...not necessarily the tire dealer for those. I used white modular trailer wheels for my 15" LT tires and they work super.
This link:
Tire Tech Information - Diameter Comparison of Light Truck Tire Sizes
will take you to TireRack's tire dimension page. There aren't too many size options for 16" tires that would seem to be Ok with the Toolcat height-wise; however, LT225/75-16/E's are very common and that's what I'd try if I did it over. Maybe next year I will depending on this year's performance.
   / winter tires
Thanks alot.
well 8000 with blade and balast.
Yes I am thinking of going with 235 85 16 (nokian lt )_but I am trying to find out if they will fit and how they will affect the steering.
Thanks Mike
   / winter tires #6
The subject of tires comes up often on these forums. It'd be helpful if you could post your results with whatever tire you end up with.
   / winter tires #7
That's interesting....
I have been running the 235 75 15's for what will be my fourth season with no problems. Does the B series weigh less than the other series?
I have 800 lbs of ballast, and a 1000 lb Blower on my TC's.
   / winter tires #8
New new 5600 weighs 5,500 lbs dry and empty. Load range E would give you stiffer sidewalls and little more puncture resistance. With no ballast, me, fuel, and the blower (72", SB200) I estimate my TC to run at about 6,760 lbs.
DEWFPO
   / winter tires #9
How tall are the 235 75 15's when mounted and aired up? I'd like a set at 29 or even 30 inches if it is possible. I went with the 27 inch bobcat tires cuase my dealer said the bucket wouldn't lay flat with the boom down. But for snow I don't care because it will have a blade, pusher or blower on it.
My 5610 weighs 7040# with ballast(750#) 66" bucket and an 8 foot protech compact snow pusher chained on.
   / winter tires #10
It really depends on the manufacturer of the tire. Nominally 235/75x15's should be 28.9" at proper inflation (for the vehicle) but some makes will be lower or taller.
DEWFPO
2017 Ford F-550 Bucket Truck - 4x4, Powerstroke Diesel, Versalift VST47, 52FT Reach (A51039)
2017 Ford F-550...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
American Sanders EZ-8 Electric Floor Sander (A49461)
American Sanders...
2008 Ford F-250 Reading Service Truck (A50323)
2008 Ford F-250...
2022 LEGUAN 190 SPIDER LIFT (A51242)
2022 LEGUAN 190...
POWER BNG2800IE INVERTER GENERATOR (A50854)
POWER BNG2800IE...
