winter oil
/ winter oil #1
hft
Edmon ton
JD 3038e
I need a lighter oil for winter in my Yanmar 3 cyl diesel as I don't or can't have it plugged in and the 15W40 is too heavy to allow the unplugged engine to start. Thinking of using a 5W or0w oil. Will this work better?
/ winter oil #3
Welcome from Ea WA state. Kubota recommends either 15W40 or 10W30 for year round use. I would post on the fuel/oil forum as mguitas suggests. Personally, I use 15W40 year round and have no difficulties. However, you probably get a little colder & for longer periods.
/ winter oil #4
10w-30 semi-synthetic or 5w-40 synthetic Rotella work fine for me. 5w-40 synthetic Delo is also good and easily available here. It's what will go in my machine in another month.
/ winter oil #5
I just bought oil for my B2650 and dealer said to use 10w 30 for winter use . I use 15w 40 rotella with my M5700 all year long but that has a block heater .
/ winter oil #6
Just make sure its rated for Diesel use.. And you probably want to get a synthetic
/ winter oil #8
I use NH Mastergold 10W-30, but I plug it in. I wouldn't dream of starting it at -5F with that oil unless it was plugged in. I would use 5w-30 for colder starts unplugged. I used 15W-30 last year and plugged in. It was more sluggish than with 10W-30 in starting. In Maine 10W-30 is an all season oil for my tractor (rarely in the 90's).
/ winter oil #9
Good points here.
For those of us whose climate is "far north", the 5w-40 and 10w-30 give us an oil that is suitable for year around use. These oils "fit" us and our climate well. I've never used the common 15w-40 and likely never will.
Nonetheless, I do indeed like my plug in block heater. When it is −30, it gives me confidence to fire up that diesel and put it to work.
207273 (A52708)
207273 (A52708)
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
2004 DCT PUMP TRAILER (A58214)
2004 DCT PUMP...
SKID STEER ATTACHMENT CEMENT MIXER (A58214)
SKID STEER...
24in pin on tooth excavator bucket (A61307)
24in pin on tooth...
Hercules Pesticide Applicator with Nozzle (A61568)
Hercules Pesticide...
