Winter Mower Storage. Drain the gas? Stabil? Start it once a month?
   / Winter Mower Storage. Drain the gas? Stabil? Start it once a month? #11
i run rec gas (ethanol free) in all my outdoor power equipment and have no issues starting up in the springtime.
   / Winter Mower Storage. Drain the gas? Stabil? Start it once a month? #12
Since I moved out here in '82. Stabil in my gas for the riding mower - year round. I use gas with ethanol. Then do my last mow job - usually about an hour. Hook up a smart trickle charger and leave it on the battery for 24 hours. Do the trickle charger routine every two months. Store the mower in an open carport stall. The mower has always started right up in the spring. That's 38+ years of doing it this way.
   / Winter Mower Storage. Drain the gas? Stabil? Start it once a month? #13
Remove gas station gas. Refill with engineered fuel such as TruFuel (Lowe's). Run 5 minutes. Next spring start 'er up on the first pull.
   / Winter Mower Storage. Drain the gas? Stabil? Start it once a month? #14
I've been using the Stabil 360 for 3 years. Like others, I add it to every 5 gallon containers when I fill it year round. I get it in quarts with the measuring tube on the bottle. 1 oz. treats 5 gallons/160 gallons in all. It stabilizes, and cleans, eliminating having to add Seafoam at the same time, with regular Stabil. I use it in anything from my 50's era vintage garden tractors, to up to my 65 hp farm tractors, and everything in between, except my newer Stihl saws, which I use Marine (no ethanol) gas in.
I also use battery maintainers w/desulfater on several pieces, from my backhoe, Dodge Cummins Dually I pull the horse trailers with, to my Super C Farmall which I leave on the manure spreader most of the year, and 4-wheeler that don't get used as often. Two of those are 6V/12V so as to use on my older tractors, so they are always ready to go when needed, especially through the winter. These range from the $40 Harbor Freight model, to a couple more expensive brands. The HF one is on it's 3rd year, hooked up all the time to my Super C, so I can check it twice daily while doing chores, and still works fine.
   / Winter Mower Storage. Drain the gas? Stabil? Start it once a month? #15
Since ethanol came into use in Massachusetts, I have had problems with it in small engines. In my 4 cycle, ( lawn tractor, wood splitter, Dr brush mower, Dr power wagon, and a 36 year old Troy built rototiller)I use stabil, and premium gas at the recommendation of my mechanic.
That did not help my 2 cycle. After replacing carburetors in 3 chain saws and 2 Brush cutters, I switched to the premix available on the shelf. My mechanic recommended using that ethanol free premix when I store the machines, but , I use it exclusively. While expensive, at least I’m not replacing carburetors.
   / Winter Mower Storage. Drain the gas? Stabil? Start it once a month? #16
ethanol free fuel w/stabil run all yr around, i am not a fan of running dry.
given the horror stories of ehanol fuel in small engines, don't understand why some don't get that message.
   / Winter Mower Storage. Drain the gas? Stabil? Start it once a month? #17
I've often wondered. Are there different formulations for ethanol gas - by region. Why are some having so much trouble - others having very little.
   / Winter Mower Storage. Drain the gas? Stabil? Start it once a month? #18
I run engine dry of gas in all 2 strokes and mowers fill gas tank add stabilizer remove battery inside yet to have problem spring start up.
   / Winter Mower Storage. Drain the gas? Stabil? Start it once a month? #20
It only been a couple of years since I have been able to get premium ethanol free nearby. With the ethanol fuel I only had problems when the fuel was old, more than 6 months or left the fuel tank below half full.
If I am going to store something an unknown length of time, say more than a few months I run it empty or shut off the fuel and run it dry. My other stuff I almost always use stabil and just let it sit until the next time I use it.
Heavy Duty 10,000lbs Two Post Car Lift (New/Unused) (A59225)
Heavy Duty...
2023 Kubota KX057-5 Compact Excavator (A56436)
2023 Kubota...
Wood Gliding Bench (A57149)
Wood Gliding Bench...
2012 DIAMOND C  40FT GOOSENECK TRAILER (A58214)
2012 DIAMOND C...
CASE ROOT PLOW (A58216)
CASE ROOT PLOW...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
