Winter Mower Storage. Drain the gas? Stabil? Start it once a month?
   / Winter Mower Storage. Drain the gas? Stabil? Start it once a month? #61
Well..... I have forgotten the alternatives listed in previous posts, other than using Stabil.
I never indicated that I needed, or wanted, 100 octane!
What I want, and need, is zero ethanol content!
Where would you suggest that I purchase non-ethanol gasoline?
You want non-ethanol gas, but you don't need non-ethanol gas.
   / Winter Mower Storage. Drain the gas? Stabil? Start it once a month? #62
   / Winter Mower Storage. Drain the gas? Stabil? Start it once a month? #63
Your locale dictates IF you can buy it at all. In RURAL Iowa, Casey's sells it. Not available in Illinois or Indiana. Many outdoor equipment places sell it, but it's really expensive.
The state law here is: "No non-ethanol fuel may be dispensed from a pump"
   / Winter Mower Storage. Drain the gas? Stabil? Start it once a month? #64
   / Winter Mower Storage. Drain the gas? Stabil? Start it once a month? #65
   / Winter Mower Storage. Drain the gas? Stabil? Start it once a month? #66
I need non-ethanol fuel. I have two ATVs that often set for months. Before I switched to non-ethanol fuel, if I let either of the ATVs set for a few months I would have to clean the carburetor. Since I switch to ethanol free fuel I have had no problems.
   / Winter Mower Storage. Drain the gas? Stabil? Start it once a month? #67
I am pleased to be informed what I "need"!
You could use Stabil in E10 and then you wouldn't be burning leaded fuel, and your engines would last longer. It's a lot less expensive as well. Therefore, the conclusion is you don't need 100LL, you want to use it.
   / Winter Mower Storage. Drain the gas? Stabil? Start it once a month? #68
You're not burning 100LL avgas are you?
   / Winter Mower Storage. Drain the gas? Stabil? Start it once a month? #70
I have no experience with 100LL, race gas, or even "high" octane gas at all. But I do have to say that here in S Ca if I don't run my 2 cycles dry at the end of a usage...I will have carb problems once I try to re-start. My truck, and other 4 cycles, seem to be able to get through the off sessions. Although my truck is run almost daily and for my portable generator I have a valve set-up in my gas line to drain the tank once I'm through using it at that time.
It might sit unused for "months" and I dare not let ethanol gas sit in the tank because it "will" gum up the carbonator!! BTDT too often to bother with messing around any longer. I have found that the best way to avoid carb tinkering is just run "em dry and put 'em away. Sure it may dry gaskets some, but it absolutely doesn't gum up any more carbs! I like to be able to grab a machine when needed, put in fuel, pull the rope and do my work -- without having to take apart a carburetor, massage the engine, then an hour or two later get my task done. I use stabil. seafoam, marvel mystery oil, and blind luck to no noticeable results. After reading all the above comments I can't say that high octane gas is hurtful or helpful...but I believe I'll stay with my methods for now.
MossRoad you make good points but sometimes it just doesn't matter - a 5 to 10 minute chainsaw job turns into hours of frustration and tinkering. Perhaps (almost certainly) your gas is processed differently than ours or others and your methods work for you. They don't for me. Just saying a different perspective on this issue is always available and worthy of thinking about.
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
SKID STEER GRAPPLE BUCKET (A58216)
SKID STEER GRAPPLE...
2018 Ford F-150 Pickup Truck (A56858)
2018 Ford F-150...
2020 Global R3 Air Street Sweeper (A56858)
2020 Global R3 Air...
2012 TOP HAT TRAILER GOOSENECK FLATBED TRAILER (A58214)
2012 TOP HAT...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
