Snow Winter is coming snowblower question
/ Winter is coming snowblower question #41
I have over a mile of dirt road to maintain and I have a B7800 with a 60" rear mount snowblower with front loader and it has been perfect for maintaining a wide road with no snow banks. The snowblower is a JRW (Canada) and it is a terrific machine. I paid $1700 for it new in 2003 and other than a few shear bolts I have had to do nothing other than normal maintenance to it. It is a heavy gauge steel and the auger is solid.
The front end loader adds the needed ballast - plus it makes moving snowbanks where the State plows the main road easy and it is nice to be able to scrape areas where I don't want to scape with the blower. I don't use chains and have never been stuck.
You plow a mile looking over your shoulder? That hurts already and its only August!
I wonder how many people have used both front and rear blowers and which they prefer?
I have only used the front blower myself.
Rob
/ Winter is coming snowblower question #42
Rob,
Running backwards is not all that bad. The blower works so fast that the job gets done fairly quickly. Having a front one would be nice, but I use the bucket quite a bit as well and the combination I have seems to make the work of getting the snow off the road with no banks real nice. I've not had a mud season problem since I started using the blower - snow melt along the road is minimal.
/ Winter is coming snowblower question #44
just to help the folks with the rear blowers- JC whitney has wireless back up cameras with LCD monitors for $99.00 usd tax and frieght to help with the stiff neck issue- maybe a right fender mount for the monitor and left fender for the camera(license bracket) they they have a huge selection of models and brands.
/ Winter is coming snowblower question #45
I have a rear-mounted 60" Meteor on a BX23 and clear a 1/4 mile long steep gravel driveway. I too wrestled with the question of a front blower and rear blade or a rear blower with FEL. I'm happy with my choice. I try to alternate which side to look back and give my body a balanced workout. Bottom line is I need the FEL for snowbanks at the road and clearing near the garage door and it was over $1000 cheaper for the rear unit. A no-brainer for me. I don't find the front end too light but I don't have an angled plow, which would react differently.
/ Winter is coming snowblower question #46
For reference, a BX23 and front-mounted blower easily walks through the County's roadside snowbanks, and allows me to blow the bank off to the side where the plow does not return the snow next pass. I also remove the county road bank, against the plow's direction for a hundred feet or so to make a notch so the next plow's pass drops snow off there, rather than in my clear-to-the-pavemant driveway.
I find that with a blower and remote chute control, I can clear everything without a blade or bucket.
/ Winter is coming snowblower question #47
I have a B2710 which I got in 2001 with a FEL and rear blower. Used it a few years like that and it was a great improvement over using a back blade and FEL on my B8200. Then someone on here had a front blower and wanted to trade for a rear, so he could use his loader as well to muck out his horse stalls. I drove the 70 miles to make the swap as fast as I could! and have never been happier. The front blower wins hands down as the best of choice. I don't even bother with the rear blade anymore, it just sits in the hedge row now. I am in the lake effect snow belt and get about 150" of snow a year, that starts in early Dec. and is here to early April! So I know a thing or two about moving some snow. Without a blower the banks get so high after a while you can't stack it any higher and it just cuts down your cleaned out area. I have a 90'x140' ice rink in the back yard and with the blower I can keep the whole surface clean and the banks way back with the snow blower, something I could never do with a back blade and FEL. Plus backing up is a pain in the *** as well as the neck! Now finally I got a like new Curtis cab off of Craig's list, so I don't have to bundle up and come in soaking wet anymore!
2022 EZ-GO ELITE...
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
Buckhorn Poly Bulk Feed Box (A66408)
Buckhorn Poly Bulk...
2004 IH 5600I Snow Plow Truck (A62679)
2004 IH 5600I Snow...
2007 International School Bus (A64194)
2007 International...
Ford 3910 Tractor w/ Great Bend Loader (A64047)
Ford 3910 Tractor...
