Winter Fuel
   / Winter Fuel #1
RobS
Super Member
Goshen, IN
None!
Is there a difference between summer and winter diesel fuel? If there is, how do I know which I'm getting? I've got to get some fuel tonight for the weekend. Trouble is, I'm slowing down for the winter so I doubt I'll use a full five gallons between now and snow (cold). Should I only get what I'll use this weekend and get more later, or just use an additive (which I use anyway). Thanks /w3tcompact/icons/smile.gif
   / Winter Fuel #2
#2 is for winter (cold weather) use.
Usually indicates it right on the pump (at the gas station).
   / Winter Fuel #3
Hi Rob,
I think Mr. Snowman is getting too excited about winter coming.../w3tcompact/icons/tongue.gif
2-D is normal diesel fuel used through-out most of the year
1-D is winterized diesel fuel {in the Northeast mostly blended with kerosene}
A good rule is fill half your diesel tank with kerosene and you won't have any problems...{if you already have 2-D in the tank}
   / Winter Fuel #4
Sorry about that - I thought #2 was the winter blend. I'm basically in the same situation as Rob in that I don't use too much fuel over the winter, so I used up what diesel I had then filled my container with #2 last week - oh well.
John - I'll do as you suggest and add some kerosene to what I have in the tank. Question - what would happen if I have a more than 50/50 blend of Kerosene/diesel - would too much kerosene make it run rough? What would happen if I had 100% kerosene (not going to do it, am just curious).
Actually - I am eagerly awaiting some snow - it's sleeting outside right now (Central NY). Got new chains, new back blade, newly paved 600' driveway and 2,000 sf turnaround - want to see how I do this year!
Thanks.
   / Winter Fuel
OK guys, now I'm really confused. I get my fuel at the local Amoco/Quickie Mart and there is only one pump for diesel. No choices for me. Also, I doubt the soccer moms in their diesel Mercedes are mixing Kerosene and #2 to get to the hair salon on time. Is this only a problem for us tractor owners as our fuel may sit longer than a car/truck user?
I have been using Power Service fuel supplement year 'round. Here's what they say:
<font color=red>In Winter:
Prevents fuel gelling in temperatures as low as -40°F.
Equals performance of a 50/50 blend of No. 2 and No. 1 diesel fuels
Lowers Cold-Filter Plugging Point (CFPP) as much as 36°F. – keeps fuel-filters from plugging with wax
Boosts cetane up to 4 number for easier starts
Contains anti-icing additive – protects against fuel-filter icing </font color=red>
Even with this relatively easy treatment, I doubt those soccer moms are using it. My guess is the Quickie-mart sells winter fuel year 'round? Again though, how do I know?
No offense to soccer moms, I'm married to one. Trouble is, her Mercedes is spelled "C-a-r-a-v-a-n" /w3tcompact/icons/smile.gif
   / Winter Fuel #6
Rob,
You'll be fine with the power service. You don't have to have kerosene mixed with your fuel. The dealers do it because it's cheaper than adding something like power service to prevent the freezing. You will actually be better off the way you are going as the power service will be a cleaner burn with more hp than the winter blend. My mileage on my truck always goes down with winter blend. I try and get my tanks at the house filled before they get the winter blend in and treat it with power service as well so that I can run the good diesel as long as possible. The only real advantage to the winter blend is it doesn't gel.
   / Winter Fuel #7
<font color=blue>… My guess is the Quickie-mart sells winter fuel year 'round?…</font color=blue>
No… it's whatever the supplier does… usually from about Mid October to End of April in NE US region will be winterized fuel… So soccer-mom is unaware of any changes to fuel… Most fuel stations will have signage posted stating “Winterized 1-D Fuel” on the pumps for the truckers…
Also most fuel suppliers will have limited tank storage and inventory and will only have 1-D available at their site… so delivery of “home heating oil” to that customer/farmer with the tank mounted “outside” will get 1-D fuel oil during the winter months…
{besides their supply tanks would “gel up” with straight 2-D fuel in the winter also…}
<font color=blue>… more hp than the winter blend…</font color=blue>
Yes, regular 2-D fuel has a higher “BTU” per gallon than blended winterized 1-D and “gasoline”… so in essence another reason you get better mileage and more work {horsepower/torque} from a diesel over gasoline engine…
<font color=blue>… what would happen if I have a more than 50/50 blend of Kerosene/diesel - would too much kerosene make it run rough? What would happen if I had 100% kerosene…</font color=blue>
Normally, after you cut your tank {mix 50/50}, the next time you buy fuel in the NE at the pumps… it will be winterized… so you won’t have to mix it again. On a severe sub-zero cold spell, running straight kerosene is not unheard of… but usually you will have hydraulic problems at this temp. stage {even with so called synthetic expensive hydraulic fluid…} The major disadvantage of running straight kerosene tank after tank is you don’t have the “diesel” lubricant properties the diesel engines need over long term usage…
Note-The winterized fuel comments are made pertaining to the Northeast U.S., I’m sure San Diego, CA. and Tampa, FL doesn’t know what 1-D fuel is…so obviously mixing kerosene with diesel in those area’s shouldn’t be done as it would be unnecessary…
   / Winter Fuel #8
Speaking of suppliments, I own a Ford F350 Diesel. At 15k intervals I am supposed to add 8 oz. of Ford FW-15 fluid to cooling system. Something about better cooling. Do we have anything like that for our tractors?
Jeff
   / Winter Fuel #9
Jeff,
For your tractor just use the Fleetguard extended life coolant. It already has it in it. All diesels should have an anit-cavitation supplement or coolant. Also Ford has just come out with the extended life coolant for our pickups. Well worth it to me as you don't have to change coolant for 250,000 miles and you don't have to put the FW-15 in anymore.
   / Winter Fuel #10
Re: Winter Fuel - and Antifreeze...
<font color=blue>…I am supposed to add 8 oz. of Ford FW-15 fluid to cooling system…Do we have anything like that for our tractors?…</font color=blue>
Hi Jeff,
It never fails…/w3tcompact/icons/wink.gif on TBN in the summer we discuss winter and freezing stuff… and of course in the winter we talk about mowing our lawns… /w3tcompact/icons/smile.gif
Check out this past thread on using additives and different antifreezes…
Diesel engine antifreeze vs. Gasoline engine antifreeze
2017 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A54313)
2017 FREIGHTLINER...
UNUSED HURRICANE STAND ON SKID STEER (A52706)
UNUSED HURRICANE...
FORD 555B BACKHOE (A51406)
FORD 555B BACKHOE...
Tradewinds Power Unit (A50120)
Tradewinds Power...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A52377)
2021 Ver-Mac...
