Oil & Fuel Winter Fuel Additive?
   / Winter Fuel Additive? #1
BotaBound
Hi-
This will be my 1st winter with the BX1850 and I plan on using it for snow removal, maybe 3~4 hrs. over the next 4 months (winter has not been the same these past few years - small and infrequent storms)
Wondering what folks add to their tanks out there in the colder climates (located in NH)?
-Mike
   / Winter Fuel Additive? #2
Take your pick. FPPF
I use Total Power in my diesel truck as well as the BX 24. Since I have no way of measuring the marketing claims with a side-by-side (with/without) comparison, I can only testify it hasn't done any harm, yet.
   / Winter Fuel Additive? #3
Any of the fuel additives that prevent gelling will work just fine. I use white bottle Power Service all year.
Using nothing will also work just fine since winter blend fuel, on or off-road, is usually good to about -20F or so.
   / Winter Fuel Additive? #4
I picked some up at Messick's last year, not sure what it was but I still have some it. Neil, what is the stuff your part's department sells. Good stuff.
   / Winter Fuel Additive? #5
I have never used any additives for the farm tractor. The fuel supplier will use a winter blend when refilling close to winter so at least in Maryland this has not been a problem
   / Winter Fuel Additive? #7
BotaBound said:
Hi-
-Mike
Howe's Lubricator
   / Winter Fuel Additive? #9
BotaBound said:
Hi-
-Mike
I use power service white bottle yr. round
   / Winter Fuel Additive? #10
I use Power Service in my diesel year round also. I use Stabil in all my gas equipment year round too. Actually cheap insurance for the bigger problems that can be induced by not using some chemicals. May or may not be the right things to do but makes me happy..
2019 Caterpillar 299D2 High Flow XPS 95 HP Track Loader Skid Steer (A50322)
2019 Caterpillar...
Army Generator (A50774)
Army Generator...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
Demco 365 Gravity Wagon (A50774)
Demco 365 Gravity...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2018 FREIGHTLINER...
P.T 1000 Gallon Supply Tank (A50120)
P.T 1000 Gallon...
