Winter blend Diesel
Status
Not open for further replies.
   / Winter blend Diesel #1
koziol41
I live in southeastern Wi.Does any one know when stations start selling winter blend Diesel fuel? My JD 2520 needs fuel and i would like to fill up with the winter blend since i wont be using it that much till the snow fly's.Thanks
   / Winter blend Diesel #2
Wouldn't it be easier, and safer, to just dump in some Power Service? Then there's no doubt you'd be ready for winter.
   / Winter blend Diesel #3
I'd too would put in the Power Service. I use it year round (white bottle in winter and silver bottle in summer) and it works very well.
I also use a mr.funnel I bought through Gempler's webstore
I found the winter fuel didn't run my B7800 engine as smoothly as summer fuel.
   / Winter blend Diesel #4
I tried getting some ULSD for my tractor from the local high volume station I use, but they were out awaiting a delivery later today. I asked the attendant when they were going to switch to the "Winter Mix". THe attendant did not know, but was going to ask. I use Power Service (White Bottle) year round with a double load as recommended for the Winter. Last year's ULSD "mix" from the NE distributors was less than optimal :mad:. I hope they have reformulated the mix for this season. I also use a Mr. Funnel. Jay
   / Winter blend Diesel #5
I'm pretty sure here in Western NY they start putting the additives in around November 15th. At least that is what I was tols at a few stations. I also use Power Service Year round which is cheap insurance against gelling problems.
   / Winter blend Diesel #6
There isn't always a fixed winter blend. The ratio of #1 diesel blended in to #2 to winterize it varies as the winter progresses. Mid January will probably be the most winterized fuel you can buy.
I put in no more fuel than I plan to use in one month. That way I'm not trying to run in mid January with October fuel.
If you go back and read about last winter you'll find a lot of posts from people who used additives and gelled up. Apparently ULSD gels at a higher temp than old #2 and they did not get the blend ratios right last year. But the point is, the additives did not save the day.
I would not expect a repeat of last years problems. This year's blend ratio will probably be much higher.
   / Winter blend Diesel #7
I don't know for sure when they change to winter blend, but just last week diesel went up $.19 per gallon and gas prices didn't move so I assumed the blend changed.
   / Winter blend Diesel #8
The blend isn't changed yet. The price hike is due to the conversion of diesel to fuel oil (changed the name mostly!).
As cp1969 stated, they are pretty JIT or Just In Time about matching the fuel to the temperatures. Last year they were not so much JIT but pretty much JALL or Just A Little Late, which made us SOL.
This winter should be better, but who knows? If they see mild temps, they won't treat the fuel. Then a cold snap blows thru and we all gel up like arteries in a grease freak.
jb
   / Winter blend Diesel #9
jb
I hope you are right :D But someow, I never have been able to predict the weather (wrong half the time :D )
Bob
   / Winter blend Diesel #10
You're right half the time? You are either a weather man in San Diego, or you look out the window!
Back on track,
I have already started to stock up on Howes Diesel treat. It works.
I used to use Powerservice in the white bottle, but after gelling up with the recommeded dose, adding an entire quart of the stuff, sitting in a garage with electric heater up to 75F for 36 hours it still gelled up two new fuel filters when brought out over night.
Added a 3x dose of Howes - back in the garage - worked like a champ.
My OPINION - Powerservice = no good for USLD.
Howes Diesel treat = Good for USLD
YMMV
jb
Status
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A53422)
2021 Chevrolet...
2016 CATERPILLAR 336FL EXCAVATOR (A51246)
2016 CATERPILLAR...
2008 CATERPILLAR 725 OFF ROAD WATER TRUCK (A51406)
2008 CATERPILLAR...
2007 Amkus Rescue System (A53421)
2007 Amkus Rescue...
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
2016 Dodge Caravan Van (A53424)
2016 Dodge Caravan...
