windshield washer fluid nozzle clogged M7040
   / windshield washer fluid nozzle clogged M7040 #1
Delta Dave
Mobile, AL
The windshield washer fluid nozzle is clogged on my M7040. I've tried using a needle to clear it and tried blowing it out, but haven't had any success on getting it cleared. I'm not sure if it's trash or mineral build up stopping it up. Any suggestions on clearing it or anyone know where to buy one? The dealer wants about $27 bucks for the part.
   / windshield washer fluid nozzle clogged M7040 #2
blow it from the nozzle end if there is debris in line it will be too big to pass thru the tip. Can compressed air works well with the red straw on it.
   / windshield washer fluid nozzle clogged M7040 #3
Make sure you pull the fluid hose off first. then get your air compressor fired up and backblow it with one of harbor freights air nozzles. now 3.99 used to be .99.
   / windshield washer fluid nozzle clogged M7040 #4
If it's a metal tip nozzle, remove it and soak it in lacquer thinner then blow it out with air. If plastic try soaking the nozzle in CLR cleaner then blow out.
   / windshield washer fluid nozzle clogged M7040 #5
Disconnect the supply line and use air pressure to blow any debris or clog in the reverse direction. If no it little air is flowing then check the tip and use a strong solvent to clean out. Good luck!
   / windshield washer fluid nozzle clogged M7040 #6
If you don't already have one, put a screen on the reservoir bottle. If you can't find one that fits, kludge something together. I've used cheesecloth before, that works good. Surprised how much dusty crap finds it's way in those containers.
Fire Truck (A51692)
Fire Truck (A51692)
2007 Kubota M5040D 50HP 4WD Front Loader Utility Tractor (A50322)
2007 Kubota M5040D...
Krone Swadro 46T (A50120)
Krone Swadro 46T...
1000 Gallon Concrete Fuel Tank (A50774)
1000 Gallon...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
2025 Kearney 7'x20' Trailer (A50120)
2025 Kearney...
