WINDOWS XP SP2
   / WINDOWS XP SP2 #1
frank_f15
Super Member, Rest in Peace
BUFFALO ,NEW YORK AREA
kubota b2400- R4 tires
just got my SP2 cd today, any of you folks had any problems with this sp2? anything i should do prior to installation?
   / WINDOWS XP SP2 #2
Frank, I posted a message before that if you are using Norton SystemWorks, you need to be sure it's up to date before you install SP2 (according to Symantec). I did that and then I downloaded and installed SP2; no problems, but it sure did take a long time.
   / WINDOWS XP SP2
Bird, i am only using norton anti virus, will make sure it is turned off, and all open programs closed. will be installing off cd. as i did not want to set myself up for a long download.
   / WINDOWS XP SP2 #4
I updated a couple of days ago and I didn't do anything special with Norton... just did the download and let it do its thing. I don't have any problems with it either. I have found that my typing is a little slower and my spelling hasn't improved, but other than that, no complaints.. /forums/images/graemlins/grin.gif
   / WINDOWS XP SP2 #5
I've installed Win SP2 on four computers so far. All went well, except for one. After the installation was completed "successfully," the machine hung at the XP logo screen on re-boot. Tried several time to re-boot, all to no avail. Finally, I gave up, went into Safe mode and did a system restore to a pre-install time, and then un-installed SP2 from that machine. The machine is now running just fine with the old SP1.
I have ordered the SP2 CD, and I think I'll have to spend some time in dialog w/ the MS tech service to figure this one out. It may be a matter of an unsigned driver, or something more involved.
Has anyone else experienced this problem with SP2 install?
   / WINDOWS XP SP2 #6
Your more than likely right as far as the driver issue goes. Most people buy pre-made comps and those come with a slightly different version of windows. In other words your NOT going to put Windows XP off the shelf and install it directly to your machine that was made by a co. The have there own version with alot different drivers to make that particular motherboard work.
   / WINDOWS XP SP2 #7
</font><font color="blue" class="small">( just got my SP2 cd today, any of you folks had any problems with this sp2? anything i should do prior to installation? )</font>
No problems here.
I use Norton Systemworks 2004 and Free ZoneAlarm 5.0.590, and didn't turn them off during SP2 install.
After installing SP2 I shut down some Windows background processes that I don't need based on the 'Safe' recommendations at:
http://www.blackviper.com/WinXP/servicecfg.htm
(Find 'Black or White' in his left margin and choose White for a more readable page.)
I also saw the warning that Norton Systemworks 2003 was incompatible.
This system clearly boots faster now. It should be more secure as well.
   / WINDOWS XP SP2 #8
I didn't have a problem with it. I ordered the CD since I have dial up. I see that Dell recommends running spybot or similiar to get rid of spyware before trying the installation. I didn't do that, (didn't know to) but I did shut down all running programs and defragged and ran scan disc first. I also created a system restore point, just in case of problems. The only problem I have found is that it cleaned out my address book in Outlook Express.
   / WINDOWS XP SP2 #9
I think the best thing to do before installing SP2 is to install Mozilla Firefox and forget about XP and SP2. Then, install Mozilla Thunderbird and forget about Outlook.
http://www.mozilla.org/
   / WINDOWS XP SP2 #10
I have a Gateway PC that came with XP Pro. I got SP2 installed as a regular part of Windows Update. I did nothing at all before installation and it worked just fine. The first reboot took a little longer than normal (it sat at the WindowsXP screen), but I could hear the disk drive reading so I knew something was going on.
The Windows Security Center could not recognize Norton AV 2003 software so I specified that I'd monitor that on my own. Other than that, no problems. BTW, I have a number of devices attached to this PC, e.g., external Firewire hard drive, external UPS with USB connection to the PC, and had no issues.
Note that SP2 has a lot more in it than fixes to IE or Outlook. It includes a good deal of re-compiled code in addition to new features like the security center. So, if you plan on continuing to run XP, install SP2.
New Holland 1412 Discbine Pull Type Mower Conditioner / Windrower (A55218)
New Holland 1412...
(INOP) NEW HOLLAND L328 WHEELED SKID STEER (A51242)
(INOP) NEW HOLLAND...
STORAGE FEES (A54607)
John Deere Bale Spear (A55218)
John Deere Bale...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A55218)
2-Row Peanut...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A52377)
2021 Freightliner...
