Windows Millenium upgrade to XP Pro???
/ Windows Millenium upgrade to XP Pro??? #1
Kyle_in_Tex
Super Star Member
East Central, Texas
JD 4310,JD5420
I have a Sony Vaio about 7 years old. It has some nice propietary software that came with it however, it also came with Millenium. It crashes sometimes and gives lots of alarms and warnings.
The question is, should I do a full (wipe the slate) install or an upgrade install?
The computer is an 866 pentium, 256ram, 40gig hd, dvd burner. I know we will probably need 512ram to run smoother. I can add this later if needed.
My mother uses it to email, play a few games, and view and print pictures.
/ Windows Millenium upgrade to XP Pro??? #2
We did an XP upgrade from 2000 and it solved many of the crashes your experiencing. I think you should try this first as it's a cheaper alternative and easier to do.
You need more RAM as you know. I wouldn't blink at putting a stick of 512 in there to add to your 256. That would be good.
/ Windows Millenium upgrade to XP Pro??? #3
If you don't use the Sony software, I would wipe it and start over. If you go to the Sony site you might be able to download the software. Before you wipe though you will want to go to Device Manager and get a list of all of the hardware so that you can load drivers for them after the install. Chances are XP will have drivers for most of the things, but it may save you some headache if it doesn't. Also a lot of the manufacturer's drivers have more features than the default MS drivers.
Thanks folks!
I'll see what happens and report back. I'm going to try an upgrade 1st and if I don't like it, I'll do a full install....Kyle
/ Windows Millenium upgrade to XP Pro??? #5
Window ME was not a very "nice" operating system. Before you wipe it out or even upgrade, consider installing a new hard drive and restoring your version of ME to it from the disks that came with your machine. Then, before you add any of your software, data, etc... upgrade to XP and then run all the updates for it. Then copy the data back from your original hard drive. Doing it this way prevents your current drive from getting hosed up in the upgrade and safeguards your data. Hard drives are cheap and it will be nice to have a second one for backups.
By the way, you will start finding it hard to find XP upgrades with the release of Vista, so do it quick.
Best of luck.
/ Windows Millenium upgrade to XP Pro??? #6
I think Mossroad is giving good advice. I'm currently using this Dell computer that came with Windows ME and a certificate for the XP upgrade when XP became available. So Dell later sent me the XP upgrade and I very carefully followed the instructions, only to find it didn't work. It fact, my computer didn't work at all. Several phone calls to Dell accomplished nothing. Finally one of their "tech support" guys told me there was just nothing they could do for me. Thank goodness, it was the only time I had bought a computer without promptly paying for it. I had let them finance it. So I told him to go get his supervisor and ask him where they wanted me to ship their junk, since I wasn't going to pay for it. That's when they got someone else on the phone who was able to make it work. Of course, my hard drive became drive E: instead of C: but at least it worked. I eventually did add another hard drive, added more memory, and actually bought a retail copy of Windows XP and installed it, instead of the OEM Dell XP.
So, if you do the upgrade, I hope you have better luck than I did.:rolleyes:
/ Windows Millenium upgrade to XP Pro??? #7
If you get the upgrade cd, I believe it will ask you for your original Me cd if you start from scratch, which is what I would do. I've run all the operating systems since Win95, and Me was the worst and XPro is the best. I still use a computer with 2000 at work and it runs works allright, I just think XP is a little slicker.
/ Windows Millenium upgrade to XP Pro??? #8
I did a couple of upgrades to XP Home soon after it came out. I upgraded three older Dell Pentiums and an eMachine. Did not have any problems with any of the upgrades.
You will see an improvement but beware that Microsoft requires and ID code for each machine and XP software and your original ME software. You cannot use software that was previously installed on a different machine.
After the upgrade make sure that you have SP2 included. Takes care of quite a few bugs....
Good Luck
/ Windows Millenium upgrade to XP Pro??? #9
My worst experience with crashes, etc., has been Win95. I have had a Gateway laptop with ME that operated flawlessly, much better than 95 or 98. My current desktop is an HP (3 yrs. old) with WinXP, I have a Dell Inspiron 6000 laptop (2 yrs old), also with WinXP. Both have been very reliable machines.
/ Windows Millenium upgrade to XP Pro??? #10
I'm sure the laptop came with ME, and that probably made a difference. My experience was with upgrading from Win98. I used to do a lot of fiddling and experimenting with different software and hardware and until XP came along, I used to have to reformat every 6 months or so. XP seems to take my abuse much better. I'll probably get a computer sometime this year and I'll get that with Vista.
/ Windows Millenium upgrade to XP Pro??? #11
I made the upgrade from from Millenium (what a chunk a junk!) due to constant crashes. The guru had to add memory, larger power supply and an extra fan IIRC. Also more memory but what a machine now!
Harry K
Thanks for all the input!
So far, I did not reformat the drive due to the Sony Application Recovery Disk not working correctly at bootup. I put in the XP Pro disk and it seemed to overwrite the old Millenium OK. There were a few old Dos type moments concerning the partitions that had me trying to unclog some really old braincells. Now trying to download all the updates with dial up. SSSSLLLLLOOOOOOOOOWWWW. SP2 is 108Megs at 45.2 Kbps (currently downloading).
I'll keep you posted. Our company's rent a geek said you can load an XP system type disk and register about 3 times before Microsoft will raise a flag.
The biggest problem I've had is forgetting to turn off the Messenger before logging on the net to update. I've had maybe 60 windows pop up overnite trying to get me to go to different bogus websites and that my registry was screwed up and my sytem would crash if I didn't visit those sites to fix it. I could see where a total novice would fall for something like that. This AM I turned off Messenger and they've stopped.
/ Windows Millenium upgrade to XP Pro??? #13
Microsoft will send you service pack 2 for free if you ask them. I got 2 after forgetting I already have one.
I have had Microsoft tell me that I have activated my software too many times and they wouldn't activate it again. Well after screwing things up again trying to do a dual boot with W2000 a couple of weeks ago, I reinstalled and activated with no problem. Maybe it's a number of activations in a certain time period where they flag.
And I didn't realize it was Messenger causing all the popups. I thought it was coming from my Direcway installation. The rats.
/ Windows Millenium upgrade to XP Pro??? #14
I had to dump messenger off my MIL's system.. what a bunch of garbage if i ever saw it..
Soundguy
(3) 17.5-25 industrial tires on Deere 14-lug grader rims, Coal Valley, IL (A65640)
(3) 17.5-25...
2017 John Deere 6110M (A64126)
2017 John Deere...
2022 EZ-GO ELITE...
20 Ton Hydraulic Bottle Jack (A64127)
20 Ton Hydraulic...
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2017 Ford F-250...
