windows fogging up
   / windows fogging up #11
Yes, if you have a/c in a car or truck, it is designed to run as a dehumidifier with the defogger/defroster system.
Because of lubrication issues, there is usually a temperature sensor that will cut the a/c compressor off, to protect it, at or below a certain ambient temperature.
So, in the winter, the a/c will usually not run with the defogger/defroster.
   / windows fogging up #12
As sure as Bob's your uncle, that's probably the dog's bullocks in the UK. But, since the term, "washing up liquid", is a little thin on the ground in America, I think I will ask for Never Fog at the market, so they don't think I am bladdered :thumbsup:
Ooooops:)
What do you americans call the stuff that you squirt into the sink that makes the bubbles to help get the grease off the dishes...or have you all got dishwashing machinary:D
   / windows fogging up #13
Auxilary fans like used in buses will help with this problem of lack of circulation.
   / windows fogging up #14
Small computer fans are very efficient and take little power.
   / windows fogging up #15
Turn the A/C on, set the heater control to desired temp, and set cab air to recirculate (not fresh intake). The A/C cooling condensor will remvoe humidity from the cab air (warm cab air passing over a cold coil creating condensation that goes out the drip pan) then the heater will warm up the dry air and blow it on the windows.
   / windows fogging up #16
mj007 in previous post says to do the opposite.
   / windows fogging up #17
very odd indeed. All i need to do with my DK45 is to make sure its on the outside air setting and i get no fogging. The one time i had in recirculate it did fog up.
   / windows fogging up #18
Ooooops:)
Warm English beer!:laughing:
   / windows fogging up #19
Have the A/C on and open a window slightly to get fresh air in the cab, it will clear the windows.
   / windows fogging up #20
Ooooops:)
wife with gas?
Set of 4 10-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 10-16.5...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
2013 Ford Fusion SE Sedan (A56859)
2013 Ford Fusion...
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A56435)
1992 Talbert 70...
Bucket (A55973)
Bucket (A55973)
2014 GENIE Z-60/34 BOOM LIFT (A52709)
2014 GENIE Z-60/34...
