windows 10
/ windows 10 #121
Got2Btru, Thanks, the default setting is Your Network AND the Internet, meaning MS is using your bandwidth to help others download. that SUCKS. I blocked WUDO in my firewall for now...
/ windows 10 #122
I received my 'notice' to download Win10 last evening.
Seeing as I've got a year(ish) to do it without charge, I've set a calendar reminder for the 1st of June, 2016... We'll see how the dust has settled by then.
/ windows 10 #123
I got my "notification" this morning and went with it.Took 23 minutes (VDSL) So far so good except it screwed up all the page layout and formatting in Firefox. And the 'minimise/close' controls in the top right corner (FF) no longer work. Wonder if that's to encourage me to get disillusioned and change to Edge. (not gunna happen)
/ windows 10 #124
For the guys that have installed Win 10..... did you just do an update or did you do a complete hard drive reformat and do a clean install of 10?
Do an update. You then have 30 days to do a complete rollback to where ever you started from. That's what I did when W10 wouldn't even recognize much less operate my 2nd monitor (turned out to be an old graphics card driver - we think).
My W7 Pro is working great since I rolled it back. I'll wait a couple more months before trying W10 again. We have until July 29, 2016 for the free upgrade.
/ windows 10 #125
Quote Originally Posted by HarryN View Post
That's probably best. But I downloaded Windows 10 last Sunday, then Thursday I ran Piriform's Ccleaner Professional Edition and it removed 23,786 mb; much of which was shown as "oldwindowsinstallation", so there's no going back for me.:laughing:
Incidentally, I've been using the free version of Ccleaner for a long time, and used the trial version of the Professional Edition this time. But I didn't like the Professional Edition. It cleaned every time I closed the browser, so I had to login again here and on other sites that I frequent. So I went back to the free version.
/ windows 10 #126
Ever since I downloaded and began using 10 and get into TBN, I have to refresh each time I open a new page. If not, the current postings do not show up. Is this 10 or is something wrong with TBN? This is weird.:confused:
/ windows 10 #127
I'm not having that problem at all.
/ windows 10 #128
This is not Win 10. I have the problem on Win 7.
/ windows 10 #129
I received a notice from MS that Win 10 has been loaded on my PC (all 3 gigabytes of it). Did not ask for the download, now trying to remove it to clear up the disk space.
May be time to start thinking about Apple.
/ windows 10 #130
If you pre-registered then that's what they do. M$ isn't concerned about your disk space or internet data caps or privacy. For me it would cost $8 per G ($24) to download over monthly data cap.
Today I cancelled my Windows 10 reservation so I can be in control of the download, not M$.
/ windows 10 #131
Guess what? With Apple computers you have to learn how to operate an entirely new OS. People think Apple computers will somehow run themselves but your brain has to be engaged with either type of OS. if you're going to use computers, you take the good with the bad and both types of computers have their own versions of bad. Everything has a trade off.
BTW, if you are short on disk space to where 3 gigs is hurting you, then you are limiting the capability of your machine. It's time to upgrade.
Lincoln Shield-Arc SAE-400 Engine Driven Welder (A63689)
Lincoln Shield-Arc...
Rotary Brush Cutter Tractor Attachment (A61572)
Rotary Brush...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
3PT TINE RAKE (A63291)
2015 International WorkStar 7500 T/A Dump Truck (A61573)
2015 International...
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
