Window Header Glue Laminated Size??
   / Window Header Glue Laminated Size?? #1
NY_Yankees_Fan
Veteran Member
Warren County, NJ (60 miles from NYC)
Kubota BX 2200
I am doing a remodel on my kitchen and the wife wants a bigger window over the sink. What I would like to do is remove the 2 x 10 header and replace it with a glue laminated lumber. This will give me enough space to get a taller window but keep the same width. The span is 3'6", 1st floor of a 2 story home, outside load bearing wall. Any idea what size glue laminated beam I need?
   / Window Header Glue Laminated Size?? #2
Depends how much hight you're wanting to gain? the smallest width of LVL beams I have worked with are 2 x 10 same as a standard wooden 2x10, then they go next to a 3 x 10 which is what you need, you would then have to rip it down to what ever would be needed? however by doing so I cannot see how would be achieving any more strength then a sandwiched 2x? with plywood in between:cool: You could perhaps get some 1/2 steel plate and use instead of plywood, But again just how much hight we talking about? does the house have taller than 8 ft ceilings? Like 9 ft or higher? it could be as simple as removing the cripples, Is the second floor cantilevered out over the window? or even with the wall bellow? is there a roof hip above? or gable above?
   / Window Header Glue Laminated Size?? #3
Less than 4 foot i would take 12 inch micl.rip it in half 6 inch would work.
John Deere Miniature Decorative Truck (A55758)
John Deere...
New 4x6 Chicken Coop (A50775)
New 4x6 Chicken...
2016 Chevrolet Malibu Sedan (A53424)
2016 Chevrolet...
John Deere 85G Quick Attach Brackets (A50775)
John Deere 85G...
1995 Rinker Captiva 190 (A55302)
1995 Rinker...
Swict 78" Bucket (A53316)
Swict 78" Bucket...
