Windmill FAIL
   / Windmill FAIL #1
o2batsea
Platinum Member
Maryland
Kioti DK45C 2005
finally got round to putting up the pond aeration windmill. It was going pretty well until the thing was about ten feet up. At that point the fiberglass pole I was using for a support gave out and the thing came down head first. I think I can save some of it, but it's pretty jacked up. As they say, back to the drawing board.
   / Windmill FAIL #4
youch!
details of size that it was?
   / Windmill FAIL #5
Pics or it didn't happen (don't you wish, right? :D)
Sorry to hear about it, but I still want to see the carnage :ashamed:
   / Windmill FAIL #6
That don't sound good. I have a couple to put up. The latest was found on a rock pile that fell from a 40 foot tower. the case is fine and it took a day to reshape the wheel and sails. Probably need a crane to set them so I hope to get all three ready for one trip.
   / Windmill FAIL #7
sounds more like a tower failure, if you could call that a tower. hope you can salvage it,
I realize this is a different kind of mill, but they can be set up with out a crane,
this one a 54 foot tower, and a 12 foot mill close to a 1000 pounds in the head,
and this is taking the tower down when it was only 40 foot with out the head on it,
I used a Jin pole to take the head down, took the fan sections off first, and then the head, moved it in one piece, and then made a new lower section on it for 14 foot more height, on the tower,
   / Windmill FAIL
Thanks for all the replies. Yes it's a homebrew windmill, a Lenz 2 turbine vertical that works a pair of bellows.
The glass support pole was just a bit undersized I guess. It was going up fine but the pole was deflecting quite a bit and it let go on what appeared to be a weak spot. It had gone up ok in earlier tests but that maybe weakened it for the real deal.
In any case the frame and the spokes the wings mount to got wrecked, but the wings themselves are ok and those are the most important thing anyway.
The new frame will be steel not fiberglass. The spokes will be more robust and the bellows strengthened.
I also plan to place it on the shore line where the breeze comes in off the chesapeake rather than back in the woods where it is sheltered. That way it need not be up high, it can be almost ground level and get tons of wind. Just hafta run a long garden hose back to the pond.
CAT 289D3 (A58214)
CAT 289D3 (A58214)
1449 (A57192)
1449 (A57192)
30ft Highway Trailer Co. Lowboy (A61306)
30ft Highway...
2016 Freightliner M2 106 Altec AM50 50ft. Bucket Truck (A59230)
2016 Freightliner...
2021 CATERPILLAR 259D3 SKID STEER (A60429)
2021 CATERPILLAR...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
