Winches
   / Winches #1
MF283
Platinum Member
Lebanon, TN
JD 5303 JD 920M JD825I XUV Gator
I got my JD XUV last November, it has a place for a winch on front & i know they make hitch mounted ones for the rear as well.
While i have a tractor to do pulling or other things when necessary, i was wondering , those of you that have winches on your off road vehicles, do you really use them a lot & do you think it's money well spent??
Thanks,
Ronnie
   / Winches #2
I rarely use my winch. But when i have used it, it was a must have.
   / Winches #3
I would venture to say that most winches are seldom used. Unless you do a LOT of off-roading, you will probably seldom use it. I see ATV's with their winch hooked to a log/tree, pulling it. WHY??? Hook a rope/chain to the log and pull it with the ATV. Either way - if the log is too heavy neither the winch or ATV will pull it. If the log is too heavy - the winch will simply pull the ATV towards the log. A winch becomes a pretty expensive status/macho symbol.
Had a friend with a Warn winch on his Jeep. It only sat there on the front bumper and he never found out how to use it. The day he & his wife got stuck with the Jeep - he sat there for four hours before calling me to come help. By the time I got there he had all the winch line unspolled & completely soaked/covered in mud, the battery was hotter than the surface of the sun from constant use/recharging and the wife was seriously considering walking out to the county road and hitching a ride home. It was not a pretty picture.
About 50% of the time when I would get the Jeep stuck and need the winch - there would be nothing to attach the winch line to. Bring on the double-fluke boat anchor. Start the anchor into the ground and believe me the winch will completely bury it. I learned quickly what a ten foot "back line" was for.
Remember - if you do a lot of off-roading, you are probably in an area where some form of tow vehicle would never be able to reach you. In this case a winch can be a real life saver. But only if you know how to use it - and use it safely.
   / Winches #4
   / Winches #5
Can't see a winch mounted on the front;what if you need to pull backwards.Only good use is raising a snow plow.Looks like you have a tractor to pull your self out if stuck.
   / Winches #6
Lot of good stuff in this post. Great examples of not understanding a winch. A winch requires a good platform to pull from. A good anchor point. And a good power source.
A properly sized and powered winch should easily be able to drag the host vehicle.
   / Winches #7
Thanks,
Ronnie
Ronnie, I don't think we can answer that for you. We don't know how often you put your vehicle in a potential "stuck" situation. If you could add some clarification of that our added comments would be more logical.
   / Winches #8
No flame intended so please don't take this comment as that. :)
You defintel don't need a winch.
Ronnie, this post is an example of what I mean. Nybirdman's uses don't justify the cost of a winch. :)
   / Winches #9
What if it's mounted on the back, and you need to be pulled out forward???
SR
   / Winches #10
nybirdman,Sawer Rob:
Warn winches makes a winch that attaches to the ball hitch on the stuck vehicle. So you carry the winch in the vehicle in its cute carry bag and when you need it - attach to the ball hitch. This allows for a strong ball anchor point on both the front & back of the vehicle.
2017 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A50323)
2017 GMC Sierra...
ATTENTION! PLEASE READ (A50121)
ATTENTION! PLEASE...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
2014 Peterbilt 384 T/A Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
Bobcat Skidloader PHD (A50774)
Bobcat Skidloader...
Mayrath 10 x 31 Truck Auger (A50514)
Mayrath 10 x 31...
