Winches
/ Winches #1
MF283
Lebanon, TN
JD 5303 JD 920M JD825I XUV Gator
I got my JD XUV last November, it has a place for a winch on front & i know they make hitch mounted ones for the rear as well.
While i have a tractor to do pulling or other things when necessary, i was wondering , those of you that have winches on your off road vehicles, do you really use them a lot & do you think it's money well spent??
Thanks,
Ronnie
/ Winches #3
I would venture to say that most winches are seldom used. Unless you do a LOT of off-roading, you will probably seldom use it. I see ATV's with their winch hooked to a log/tree, pulling it. WHY??? Hook a rope/chain to the log and pull it with the ATV. Either way - if the log is too heavy neither the winch or ATV will pull it. If the log is too heavy - the winch will simply pull the ATV towards the log. A winch becomes a pretty expensive status/macho symbol.
Had a friend with a Warn winch on his Jeep. It only sat there on the front bumper and he never found out how to use it. The day he & his wife got stuck with the Jeep - he sat there for four hours before calling me to come help. By the time I got there he had all the winch line unspolled & completely soaked/covered in mud, the battery was hotter than the surface of the sun from constant use/recharging and the wife was seriously considering walking out to the county road and hitching a ride home. It was not a pretty picture.
About 50% of the time when I would get the Jeep stuck and need the winch - there would be nothing to attach the winch line to. Bring on the double-fluke boat anchor. Start the anchor into the ground and believe me the winch will completely bury it. I learned quickly what a ten foot "back line" was for.
Remember - if you do a lot of off-roading, you are probably in an area where some form of tow vehicle would never be able to reach you. In this case a winch can be a real life saver. But only if you know how to use it - and use it safely.
/ Winches #5
Can't see a winch mounted on the front;what if you need to pull backwards.Only good use is raising a snow plow.Looks like you have a tractor to pull your self out if stuck.
/ Winches #6
Lot of good stuff in this post. Great examples of not understanding a winch. A winch requires a good platform to pull from. A good anchor point. And a good power source.
A properly sized and powered winch should easily be able to drag the host vehicle.
/ Winches #7
Thanks,
Ronnie
Ronnie, I don't think we can answer that for you. We don't know how often you put your vehicle in a potential "stuck" situation. If you could add some clarification of that our added comments would be more logical.
/ Winches #8
No flame intended so please don't take this comment as that. :)
You defintel don't need a winch.
Ronnie, this post is an example of what I mean. Nybirdman's uses don't justify the cost of a winch. :)
/ Winches #9
What if it's mounted on the back, and you need to be pulled out forward???
SR
/ Winches #10
nybirdman,Sawer Rob:
Warn winches makes a winch that attaches to the ball hitch on the stuck vehicle. So you carry the winch in the vehicle in its cute carry bag and when you need it - attach to the ball hitch. This allows for a strong ball anchor point on both the front & back of the vehicle.
17601CFL (A59228)
17601CFL (A59228)
Paladin 12in Digging Tooth Bucket Excavator Attachment (A60352)
Paladin 12in...
2013 Dodge Charger Sedan (A59231)
2013 Dodge Charger...
TAKEUCHI TL6R SKID STEER (A59823)
TAKEUCHI TL6R SKID...
2018 Husqvarna 21in. Push Mower (A59231)
2018 Husqvarna...
Giyi GY-TB47 Forklift Telescopic Boom (A60463)
Giyi GY-TB47...
