Winch use
   / Winch use #1
cef2lion
Central PA
JD 4410, JD455
I have a winch coming for my XUV. Where I use the XUV there will be a good chance that I will not have anything handy to hook onto. I cross a lot of open fields. Is there a device I can use with the winch that might be able to hook into the ground or snow that I can pull against?
Craig
   / Winch use #2
Dick Cepec used to have a devise that one had to bury sort of like an anchor, so you still need a shovel, but it works in sand, dirt, etc.
   / Winch use #3
I bought an anchor to use with an atv winch several years ago, and never used it. It is basically a mobile home tie down with some square tubing on top so you can twist it in the ground. I think I bought it from Cabela's.
If you do find a tree, an extra tow strap will give you some more lenght and you will need a clevis and tree strap. I have seen people run the cable around the tree and hook back to the cable. This will ruin your cable pretty quick. JC
   / Winch use
I searched google and find one product called Pull-Pal. They have a model for ATVs that should work with utility vehicles. Will do some additional searching.
Craig
   / Winch use #5
I have a pull pal for my truck. It works very well, but they are costly. JC
   / Winch use #6
i use a moble home tie down anchor the kind you have st screw into the ground that is about 3 feet long. i also carry about 100' of rope plus 2 14' tow strapsand i got 50' of cable on my winch so i can reach out to a tree or pulling abject atleast 175' away when i'm stuck and i been wanting to add another 100' to the rope.and all this winch talk reminds me i need to chang my winch cable i think it's about time it's three years old and in good shape but i think i would feel better if i had new cable.
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A52141)
2006 CHEVROLET...
2016 CATERPILLAR 336FL EXCAVATOR (A52705)
2016 CATERPILLAR...
2006 V.E. ENTERPRISES 130BBL TANKER (A53843)
2006 V.E...
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
25in x 10in Kubota RTV-X1140 Tires (A52377)
25in x 10in Kubota...
