Winch mount for jd xuv 850
   / Winch mount for jd xuv 850 #1
Bigjune
Jd 5320
Tying ready to take delivery on a xuv 850d. The dealer has given me 2 options for a winch mount. The first one sits within the brush guard. The other one fits into the trailer hitch and can be moved to the front or back. Anyone have any advice with regard to what is better or makes more sense
   / Winch mount for jd xuv 850 #2
My brother has the HPX, very similar to the XUV. He has the receiver mounted winch which is wired for the front or back. That makes the most sense to me. It is a nice option to be able to winch from front or back, or, rescue yourself from whichever end makes better sense. That's what I'll do if I ever get a winch for my 850D.
What winch are you getting?
   / Winch mount for jd xuv 850 #3
Definitely receiver mount. I have had both and the increased versatility of the receiver mount makes it the way to go.
John M
   / Winch mount for jd xuv 850 #4
I have an XUV with the receiver mounted winch in front. I like the receiver mount in front because it can be easily removed and one of these days I will wire it so it can be used from the back
   / Winch mount for jd xuv 850 #5
See my last post re: "Ranger Winch". Receiver mount with the Anderson Power Plugs makes life easier!!!!!!!!!!
JW5875
   / Winch mount for jd xuv 850 #6
Only concern I see with receiver mount is, can it still be used for a lift system when and if you install a snow plow?
I agree the receiver system is the most versatile and you usually need to pull your self back out of a sticky situation, so rear mount capable is a big plus.
   / Winch mount for jd xuv 850 #7
i have mine on a receiver mounted....have power run in front and rear both....winch is wireless remote...
   / Winch mount for jd xuv 850 #8
I have the reciever mounted winch on my 855D. I have been using it with an eagle snow plow and it works fine. I like being able to use the winch on the front or rear.
UNUSED FUTURE 32"...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
New/Unused SD Lanch SDLE20 Mini Excavator (A57453)
New/Unused SD...
2012 PETERBILT 388 WINCH TRUCKS (A58214)
2012 PETERBILT 388...
2012 PJ Trailers PJFS25 25ft T/A Gooseneck Flatbed Equipment Trailer (A55973)
2012 PJ Trailers...
VIDEO LINKS FOR ALL LOTS W/ VIDEOS (A59213)
VIDEO LINKS FOR...
