John_Mc
Elite Member
- Joined
- Aug 11, 2001
- Messages
- 4,048
- Location
- Monkton, Vermont
- Tractor
- NH TC33D Modified with belly pan, limb risers & FOPS. Honda Pioneer 520 & antique Coot UTV
I have old Coot ATV/UTV. That I would like to install a winch on. I've got a 2" receiver on the back, so will probably make up something to have a 2" receiver on the front as well to have the ability to swap it back and forth.
I'm wondering about the battery: The Coot is powered by a 16HP Briggs Vanguard engine (replacing the stock 12-14 HP Tecumseh). If I remember correctly, it has a 16 Amp alternator. The battery is the type you would expect to see in a riding lawnmower. Obviously too small for use with a winch. Unfortunately, the space for the battery is too tight to fight anything bigger in there. The Coot consists of two tubs, joined at pivot in the middle. Battery, engine, and transmission are in the front tub. I like keeping the rear tub empty for hauling stuff, but I could just put a deep cycle battery back there temporarily when I need it for winching, and remove it when need the cargo space.
I was thinking of hooking up the deep cycle battery in parallel to the stock battery when I'm likely to need it. I'm curious whether there are problems paralleling two very different batteries. I know starting batteries don't like to be deep-cycled, and deep cycle batteries don't like the heavy current draw of starting (maybe that's not too much of an issue, since it's just starting a 16 HP V-twin, and not a big diesel engine?) Am I asking for trouble connecting them together? I do know they need to be the same type of battery (i.e. don't mix a flooded lead acid with an AGM) and they should both be in a similar state of charge before connecting them together (to avoid the fuller battery "dumping" it's charge into the drained one at an unsafe rate). Just curious what others have done in this circumstance.
