Winch added to the oliver oc3
   / Winch added to the oliver oc3 #11
Bunch of years back we (neighbor and I) owned an OC3.
LOL we paid all of $400. for it so at $200 each it was our big boy's toy.
It had a dozer blade that power angled to the right. (still have the cylinder)
Some things I learned that I pass on FYI.
The under carriage is common with smaller rock drilling machines. (track, rollers sprockets etc)
Engine I seem to recall is continental 4 cyl common in early jeeps and other industrial machines.
Mine unfortunately was rolled by a guy I had loaned to and he cracked open the differential housing which never could be repaired properly so I had to scrap it.
I only discovered that damage after I had purchased replacement undercarriage parts (drilling machine), shucks I even had a brand new motor from Gov't surplus for it.
Gas tank location was my main issue* as my terrain is very hilly and only a full tank allowed me to climb plus at any cross slope work always resulted in throwing a track as the undercarriage had been so abused.
LOL, got so efficient that using a bar I could 're track' without a helper, lots of practice!
But it was fun to own and I did landscape much of my property.
I later on bought a HD6 Allis that served me well.
*I should have simply added a second fuel outlet at the other end of the tank.
   / Winch added to the oliver oc3 #12
The engines were all Hercules, started with the IXA-3 in the HG3, then the IXK-3 and finally the IXB-3 in the OC3.
I've seen the mining equipment that uses the same undercarriage but can't remember the company name.
I borrowed my buddy's HD6G to help do the site work for my new shop, ripped a lot of ground with it, need to pull the steering clutches out and adjust them and replace the steering brakes, not a fun job.
All set for the woods. The arch works well on the front for some of the tight trails. Straddle log, lift up so tongs engage and then back down to lift log
   / Winch added to the oliver oc3 #14
That's a pretty good setup you got, did you do the model A aux. trans or were you lucky enough to find a factory setup?
2016 Chevrolet Traverse LS SUV (A53117)
2016 Chevrolet...
2008 Isuzu NPR-HD Landscape Dump Truck (A53422)
2008 Isuzu NPR-HD...
2019 FREIGHTLINER M2106 DEBRIS BUCKET TRUCK (A51406)
2019 FREIGHTLINER...
2017 TAKEUCHI TS50V SKID STEER (A52706)
2017 TAKEUCHI...
Ford 600 Tractor (RUNS) (A50775)
Ford 600 Tractor...
