Will this work with my TC33D?
   / Will this work with my TC33D? #1
Williecoyote
Central Wisconsin
TC33D
I just bought a King Kutter 72" box blade. Will my TC33D Hydro be able to pull it in our sandy/rocky soil? I wanted to go with a 66", but would have to special order it and it would take to long to ship. Fleet Farm only gets a couple of shipments a year on KK stuff. The rear wheels on my tractor have about a 60" spread. I would like to know if it will work or not, so I can return it, before I use it. I don't think they want a used box blade back.
   / Will this work with my TC33D? #2
Have 61" one from tractor suppliy, just a couple inched wider than the tractor. In 1st @ 2800rpm, box can stop my tractor dead!!! Don't beleive I would try a bigger one. Just my 2 pennies......
Ron
   / Will this work with my TC33D? #3
While I can't tell you that it'll work with yours in your area, I own a 72" and have no problems using it moving anything I choose. You may not be able to sink it as deep as you could a 66" but you'll be moving the same amount of material. The only person that can really tell you if it'll work for you is you. The Ideal situation would be for you to rent one and try it.
   / Will this work with my TC33D? #4
I have a tc 30, hydro, with a 6' kk box and I have no problems. I usally use mid-range, but if I have a full load in the box i'll use low gear and about 2000 rpm's with the machine in 4x4. just go light on the hydro pedal and it'll work just fine. It really doesn't even bogg the engine down I think it's all in the use of the hydro pedal. good luck.
   / Will this work with my TC33D? #5
I have a TC33DA and use a Bush Hog brand 60” Box Blade MBX600. The problem I run into is traction, I have loaded R4 tires and they spin and slip like I am at a tractor pull. I might get AG tires next time around. Nobody in my area thinks tire chains are a good idea. My guess is the 72” will work, but my personal preference would be for the box matched to your tire width.
   / Will this work with my TC33D? #6
I can give you my take, as I am using a 60" KK boxblade from Fleet Farm. The reason I went with the 60" is that I wanted to cut trails through the woods and wanted a minimum footprint getting between trees. I also use it for grading my crushed granite driveway and doing some leveling for landscape. The driveway and the landscape are not a problem, and the wheel treads do not show - I can get up to the edge of the grass w/o worry. The only thing that has stopped the 60" is some gnarly white pine and hemlock roots caught in the ripper shanks. I just finished roughing out my trails and I had a blast - I am now eyeing up the neighbor's land! /forums/images/graemlins/smile.gif
Thanks for the input /forums/images/graemlins/cool.gifI tried the 72" BB and the tractor could pull it unless the box was full and I would encounter a sandy section in the drive. Then all 4 tires would spin and I would have to lift the BB to a point where I could move again. That would just leave a big lump in the drive, sort of defeating the purpose of leveling. I took the 72' back to Fleet Farm. Since the BB only had minor paint removal on the sides, they charged me $10. Instead of getting $40 back for the difference between the 72" and 60", they gave me back $30. Not a bad deal! The 60" works better, but even with the smaller one I have spun the tires. It only happens in the sandy sections of driveway. I need to learn how to adjust the BB while on the move. /forums/images/graemlins/confused.gif If anyone has any pointers on how to use the BB, I'll take'em. /forums/images/graemlins/cool.gif
   / Will this work with my TC33D? #8
I am learning alot by playing around with the top link adjustment. By adjusting the angle of attack, you can get the get the blade to stay shallow. I now understand why so many posters advocate the use of hydraulic top links - if you have the remote controls to support them. Good luck, keep playing.
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A52472)
2013 TEXAS PRIDE...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
GS-3246 MAN LIFT (A52472)
GS-3246 MAN LIFT...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
