will this work for a top link?
   / will this work for a top link? #1
prof fate
Platinum Member
beaver pa
kioti ck3510 Cub Cadet 149, 2146, Toro Zero Turn
Delavan Ag Pumps Hydraulic Cylinder 2 X 8 PML28-112ASAE
I believe the size/price are good...
I have rear remotes - so need the connectors and lines.
Anything else needed?
this one is double the price..similar size/specs. endd are 3/4 not 1" which is probably better, but I'm sure I can find a sleeve to bring 1" down to 3/4 for the cheaper cylinder.
Hydraulic Top Link-Tractor, 3 point | Agri Supply 9599
Check valve?
Double Pilot Check Valve Kit | Agristore USA | Indianapolis, IN | AGRISTORE USA
   / will this work for a top link? #2
Shure that cylinder will work fine.
But getting those clevis ends to fit and work with typical tractor and implement top link fittings is going to be a bytch!
   / will this work for a top link? #3
Your first link will not work. A top link on a 3pt setup needs to have swivel balls on each end as the second link has. A 3 pt hitch moves somewhat (limited) side to side, not just up and down.
   / will this work for a top link? #4
A suitable knuckle could be a solution to the tractor end
   / will this work for a top link? #5
   / will this work for a top link? #6
Oops... Posted a link you already have.
If you google search "top link cylinder" you will come up with other options as well. I would recommend a welded one. It is not serviceable, but I feel that welded cylinders are stronger (I have no proof of this), lighter, and easier to handle.
not too concerned about servicablity, and welded seem smaller overall so that is a definite plus.
Many I find are 250 and up..plus i'll need hoses/connectors. Trying to keep this affordable.
   / will this work for a top link? #8
One issue you might encounter with a tie rod cylinder is the square plate on the base end...it may jamb up against the pin brackets ?? Also, the port is at the very end of the base...there may not be enough room for a connector and hose end fitting without interfering with the pin plates where the cylinder attaches to the tractor...!
Not sure what I may run into..new to this, got rear remotes for this specific use, on a disk and box blade for now.
I've got to measure the length..I added lower only quick attach from titan and had to get a longer top link from TSC. Also my kioti only has one mount hole for the top link. Never enough room back there anyway.
   / will this work for a top link? #10
Just beware that if anything is in a place to bind...when the 3PH is lifted all the way up with an implement (like a box blade etc.) attached it will shear off whatever is binding (like a hose fitting etc.)...
Be sure to check for clearances with the 3PH in all positions with the tallest implement attached...
Good Luck...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2006 Husqvarna YTH2148B Riding Mower (A51694)
2006 Husqvarna...
2007 Isuzu FTR Truck, VIN # 4GTJ7F1357F700209 (A51572)
2007 Isuzu FTR...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
