Will this work for a haywagon??
/ Will this work for a haywagon?? #1
Laminarman
Upstate NY
TC40DA
/ Will this work for a haywagon?? #2
How big of a hay wagon do you want. I just saw to nice ones go at an auction for about 265.00 a peice and my great uncle used to pull these with a 8n Ford and that was with 120 too 175 bales of hay on them. So give us a little more info as 4000lb capaicty is not alot even for a hayride.
Sorry about that. I didn't want to be wordy, but you're correct. I have a 40hp NH TC40DA with drawbar. I'll be going over some sloping terrain, but nothing crazy, and for chores I don't even have hay or need it, but will use it more for hauling some wood, saplings, brush...etc. I use my bucket to carry stone. Mostly it's for medium duty stuff and taking kids on rides, perhaps cutting a few Christmas trees off the property so the folks and kids don't have to walk so far. At most I'll put six to eight people at a time in it, seated down low of course, with high sides...etc. Any help again is appreciated. I cannot find a wagon at local auctions. The only one's I've found are converted manure wagons and they want over $500 and need axle/wheel repairs (but I do like the big wheels they have).
/ Will this work for a haywagon?? #4
I've seen the same thing and yes, it should make a dandy wagon for your needs. I'm hoping to do the exact same thing. Sure wish I could find one of those $2-300 wagons sitting around. I stopped at a used implement dealer the other day and the one wagon (with bed) they had was priced at $800. That's used!!! If you do this, let us know how it works out for you /forums/images/graemlins/smile.gif
/ Will this work for a haywagon?? #5
Laminarman, Yes, you can easily make a hay wagon using that running gear. I bought the 2200 pound version and built a hay wagon for it. Haywagon
There is one downside to using that running gear. It has steerable front wheels with a fixed axle. To use as a haywagon, you would be better off with running gear where the front axle pivots for steering. The fixed axle increases the turning radius and makes it much more difficult to back the trailer up. But I built my haywagon for about $300 total.
Thanks Rozette. I saw the other thread after posting mine. Are there any front axle steering units around? I think this might be a winter project. Thanks again.
/ Will this work for a haywagon?? #7
When you have a turning axle, you can tip the load over rather easy compared to the straight axle with the wheels steering at the ends of the axle. Never heard or had a problem backing up either of them.
But I have had problems tipping a load. I thought turning front axles went out with the dinosaurs. But I could be real wrong on that. I remember our little red wagon had a turning axle like that.
What do others think?
/ Will this work for a haywagon?? #8
<font color="blue"> I thought turning front axles went out with the dinosaurs </font>
Here I haven't ever seen steered front axle on ANY trailor. All front axles are turning type, and I'm not sure that anybody will want steered type one, as they don't allow you to turn sharp.
Unfortunatelly, it is true that you can tip the load over rather easy compared to the straight axle with the wheels steering at the ends of the axle, but that happend rather rare /forums/images/graemlins/smile.gif
Obviously my priority is on NOT tipping over my family. So it looks like a fixed front axle is better. Further thoughts on this are certainly appreciated.
/ Will this work for a haywagon?? #10
The picture on that site is the same as the 2200lb version and says the shipping weight is 71lbs?????? and the 2200# rated wagon is 123lbs????. If you wanted something that could also be towed with garden tractor you could go that route. Otherwise the used running gear is out there, it will be rusty and tires wont be new but can be found (near me for sure)between $250 and $400. I think the bigger tires 30" compared to 20" are a big improvement with comfort, rolling resistance, ground clearance etc..
/ Will this work for a haywagon?? #12
Laminarman, Have you given any thought to gettin a hydraulic dump trailer? Although more expensive, they are easier to steer and backup, In addition to hay, they are great for hauling grevel and firewood. willie jones
/ Will this work for a haywagon?? #13
</font><font color="blue" class="small">( Laminarman, Have you given any thought to gettin a hydraulic dump trailer? Although more expensive, they are easier to steer and backup, In addition to hay, they are great for hauling grevel and firewood. willie jones )</font>
Plus....when the kids get a little too rowdy, you can just pull the lever, and dump 'em off the back! /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif
Just kidding of course. /forums/images/graemlins/grin.gif
Dave
/ Will this work for a haywagon?? #14
</font><font color="blue" class="small">( <font color="blue"> I thought turning front axles went out with the dinosaurs </font>
Unfortunatelly, it is true that you can tip the load over rather easy compared to the straight axle with the wheels steering at the ends of the axle, but that happend rather rare /forums/images/graemlins/smile.gif )</font>
The only thing that uses pivot front axles here in the midwest USA is Anyhdrous Amonia (NH3 - nitrogen in a pressurized liquid / gas at normal pressure) tanks that the fellows like to move down the road a little fast - pivot axles don't sway and perhaps with your high-speed tractors that is what is needed.
Nothing else has those pivot axles, all wagons are steerable front axles. Way too easy to tip over a load with the pivots.
Either style of wagon is very difficult to learn to back up well. A trailer is much easier, & perhaps for small loads this person would want to consider a trailer instead.
--->Paul
UNUSED KJ 42'X30' METAL STORAGE SHED (A62131)
UNUSED KJ 42'X30'...
John Deere 4650 Tractor (A64047)
John Deere 4650...
240156 (A56859)
240156 (A56859)
2019 CATERPILLAR 326FL EXCAVATOR (A62129)
2019 CATERPILLAR...
(2) BUNDLE OF MISC SIZE USED TIN UP TO 31' LONG (A62131)
(2) BUNDLE OF MISC...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
