Will these cylinders work for an upgrade?
   / Will these cylinders work for an upgrade? #1
gsdavis1
Cleveland, OHIO
John Deere 855
I am wanting to upgrade my loader cylinders on my 70A loader. I found these priced very reasonably...cheaper than anything at surplus center. $55 each plus shipping.
They have clevis ends. I have never seen these used on a loader before. Also, the pins are 1 inch and my loader usese 3/4 inch pins. I figure I could just weld in a bushing/crosstube into the clevis holes?
The dimensions are just about perfect except they are a larger bore
Also, how do I tell if the rebuild kits are "standard" I hear people talk about this from time to time.
Here are more specs
Features & Specifications
All steel welded construction, weld-on clevis, ideal for construction and agricultural applications as well as like metal fabricating, waste/recycling and OEM manufacture of trailers
Operating pressure: 3000psi
Double acting, double ported welded
Rod: High tensile SAE C 1045, ground & polished hard chrome plated rod
Rod Seal: Deep polypak with B lip design
Rod End Clevis: Cold bended high tensile steel plate
Piston: Ductile iron ASTM A536 65-45-12, type A & type B piston available
Piston Seal: Hallite 755 provides prolonged wear resistance
Tube Seal: Buna O-ring with Polytemp hytrel back-up
Tube: Skived and roller burnished, precision finished steel for extended seal life
Tube Weldment: High tensile cold drawn tube, precision honed for extended seal life
Gland: Ductile iron ASTM A536 65-45-12, gland collar with set screws is removable from rod end
Base End: High tensile cast steel
Pins, clips & cotters included: High tensile zinc-plated steel
Thanks
Greg
   / Will these cylinders work for an upgrade? #2
Where are you getting them from? I need one myself.
   / Will these cylinders work for an upgrade? #3
As long as the clevis ends are long enough to clear everything and the eye-to eye length and stroke is reasonably close they should be no problem. Our local farm supply store sells 1"-3/4" bushings (or make your own) so that isn't an issue either...other than possibly for allowing for lubricating. If you can weld, you can alter/fabricate these any way you want. You mention that they are larger bore than the OEM 70A cylinders which will both slow down cycle times and increase lifting power. You can calculate whether this is an issue easily enough Baum Hydraulics Corp :: Spec Calculator.
Don't know where your getting these but that's a great price. FYI: I have bought almost all of my hydraulics off ebay for the last 4-5 years and gotten great deals as well.....one of my favorite sellers is National Product Sales items - Get great deals on Industrial, Electronics items on eBay Stores! they require consistent watching but you can get incredible deals from them.
   / Will these cylinders work for an upgrade? #5
As Kernopelli says...the new larger bore cylinders will both slow down cycle times and increase lifting power. An increase in lifting power might sound great but the extra capacity comes with the risk that you might be able to exceed the load capabilities of your loader and damage it. Just a reminder... :)
2020 DRAGON ESP...
New/Unused SD Lanch 20x20 Carport (A57454)
New/Unused SD...
NEW Wolverine 72in Skid Steer Tiller (A59000)
NEW Wolverine 72in...
Giyi 46" Mulcher (A53316)
Giyi 46" Mulcher...
2020 Deere 50G (A53317)
2020 Deere 50G...
Hustler super Z zero turn (A56857)
Hustler super Z...
