Will The tank Empty?
   / Will The tank Empty? #1
Frankdozer
Bridgton, Maine
1967 Case 580CK Backhoe / Loader
When I disconnect the 2 hydraulic lines from the bucket cylinder to the control valve on my dozer, will the fluid drain from the tank or just what is in the lines? Or should I just drain out all the fluid then remove the lines? Thanks, Frank
   / Will The tank Empty? #2
When your valves are in neutral, the flow is blocked. What ever is in the hose/cyl might leak out.
   / Will The tank Empty? #3
If your valve is working correctly then all you should get out of the hose is jut the fluid in them. The fluid should remain in your tank.
So no need to drain the tank to take the hoses from the valve to the cylinder off.
Chad
   / Will The tank Empty? #4
make sure that the bucket and loader are well supported since gravity will force any fluid it can out of the lines as soon as you disconnect them. A full cylinder can hold a lot of oil that will shoot pretty hard with the weight of a bucket curling to push on it.
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A53422)
2012 Dodge Ram...
YANMAR ViO45-5 EXCAVATOR (A51406)
YANMAR ViO45-5...
ROLLER DOLLY (A53843)
Anderson 31ft T/A Flatbed Equipment Trailer (A51691)
Anderson 31ft T/A...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2017 KENWORTH T880 (A53843)
2017 KENWORTH T880...
