Will skid steer attachments fit on a RK-37 tractor?
   / Will skid steer attachments fit on a RK-37 tractor? #1
ACLINE1
none
I know this may seem silly to some of you, but I am a fairly new tractor owner. When I bought my RK37, last year, the dealer told me it would accommodate any attachment a skid steer would. That being said, I have been eyeing a wolverine skid steer trencher attachment. It appears it would mount ok, but I am not sure of the hydraulic hookup, or functionality of it, once hooked up. I have a lot of trenches to dig that will be about 1000 ft, each. By the time I rent a trencher, or pay someone, I would just as well purchase the trencher. Do any of you know if the trencher would function properly after it is mounted on the tractor? I have been thinking about the joystick function, and I do not know if it would operate all the functions, as necessary. Thank you in advance.
   / Will skid steer attachments fit on a RK-37 tractor? #2
Skid steer forks, buckets, Etc. may fit your tractors QA.
But your tractor will not run most skid steer attachments that are hydraulic driven without a lot of extra pumps, hoses, and $$. It simply does not have the hydraulic flow needed.
Thank you. I figured the inanimate attachments would work, but was merely optimistic about the hydraulic attachments. I appreciate your quick response and knowledge.
   / Will skid steer attachments fit on a RK-37 tractor? #4
They do make 3pt trenching machines similar to skid steer type. Pto driven. Everything Attachments.
   / Will skid steer attachments fit on a RK-37 tractor? #5
An expensive alternative would be an axillary hydraulic pump that is powered by the PTO. 2nd suggestion is rent a mini excavator when you have all your trenches planned and mapped. Depending a lot on width and depth, you could do a lot of trenches in a few weeks.
2011 PETERBILT 367 TRI-DRIVE WITH TAG (A52472)
2011 PETERBILT 367...
2007 Chevrolet C4500 4x4 Dump Truck, VIN # 1GBE4C3247F411826 (A51572)
2007 Chevrolet...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
1999 Case 850G Crawler Tractor Dozer (A51691)
1999 Case 850G...
2013 Chevy Silverado 2500 HD (A52748)
2013 Chevy...
