Will RZT electric system power a sprayer pump?
   / Will RZT electric system power a sprayer pump? #1
mogdriver
Ponoka, Alberta
1947 Ford 8n
   / Will RZT electric system power a sprayer pump? #2
mogdriver,
Absolutely! For almost years I've had a similar unit hooked onto my old John Deere 175 Hydro without any problems whatsoever. That rig had a 14 HP Kawasaki engine with just the standard on board electricals. I did, however have a standard sized 12 volt car battery in the tractor, not for sprayer duties, but for longevity and cranking power when the tractor had sat for longer periods. I got tired of replacing the small lawn tractor battery that typically lasted only 2 years.
With the sprayer attached I wired the pump straight to the battery terminals with an inline 15 amp automotive fuse, and a dash mounted switch to turn the pump on from the tractor seat.
Most Zero Turn tractors have a much larger engine than my rig, and thusly a more robust charging system. You should have no problems at all.
   / Will RZT electric system power a sprayer pump? #3
even if the dynamo ain't up to it.. just throw on the battery from your car/truck to power the sprayer.. the lil pump will run a loooooong time off a car battery..
soundguy
2025 New/Unused Wolverine 72in Skid Steer Hydraulic Rotary Tiller (A51573)
2025 New/Unused...
New/Unused Gold Mountain Container Shelter 20ft x 20ft (A51573)
New/Unused Gold...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
6ft Field King 3 Point Hitch Tiller (A51573)
6ft Field King 3...
2022 Kobelco SK85CS-7 Excavator (A51573)
2022 Kobelco...
