Will RZT electric system power a sprayer pump?
   / Will RZT electric system power a sprayer pump? #1
mogdriver
Ponoka, Alberta
1947 Ford 8n
   / Will RZT electric system power a sprayer pump? #2
mogdriver,
Absolutely! For almost years I've had a similar unit hooked onto my old John Deere 175 Hydro without any problems whatsoever. That rig had a 14 HP Kawasaki engine with just the standard on board electricals. I did, however have a standard sized 12 volt car battery in the tractor, not for sprayer duties, but for longevity and cranking power when the tractor had sat for longer periods. I got tired of replacing the small lawn tractor battery that typically lasted only 2 years.
With the sprayer attached I wired the pump straight to the battery terminals with an inline 15 amp automotive fuse, and a dash mounted switch to turn the pump on from the tractor seat.
Most Zero Turn tractors have a much larger engine than my rig, and thusly a more robust charging system. You should have no problems at all.
   / Will RZT electric system power a sprayer pump? #3
even if the dynamo ain't up to it.. just throw on the battery from your car/truck to power the sprayer.. the lil pump will run a loooooong time off a car battery..
soundguy
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2016 LINK-BELT  235X3 SPIN ACE EXCAVATOR (A52472)
2016 LINK-BELT...
2018 FORD F-150 XL CREW CAB TRUCK (A51406)
2018 FORD F-150 XL...
2006 Hino 268 Truck, VIN # 5PVNJ81T962S11110 (A51572)
2006 Hino 268...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A52748)
2000 John Deere...
2007 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A52577)
2007 PETERBILT 387...
