Snow Will PT 60" Blade remove snow for business?
   / Will PT 60" Blade remove snow for business? #11
Re: Will PT 60\" Blade remove snow for business?
Well, a parking lot is a lot different than a driveway or sidewalks at a mall/shopping center. I've had a pickup mounted plow and I have a PT425 with a plow. In a driveway or sidewalk situation, or close to buildings, the PT425 will run circles around a pickup truck all day long. It is quicker to turn around, easier to navigate with, the plow is smaller and can get into tighter places and it can pile higher, narrower piles(plus you can pop on the bucket for deep stuff like drifts between buildings and under covered walkways, etc...). However, from my experience plowing the tarmac at airports, out in an open parking lot with no obstructions, any pickup truck worth its weight will run over the PT425. It can go much faster with a bigger blade and can go through deeper stuff just because of its weight and horspower. It can also pile high, but the piles und up being wide. The height comes from bashing the piles at the botton, forcing stuff up, whereas with the PT, you can tip the blade back as you lift, pushing the snow higher without bashing the pile. Easier on the machine and your guts.
So, I'd say it depends on the shape of the parking lot. If it is long and narrow, the PT might do OK. If you have lots of sidewalks that a pickup won't fit on, the PT will be super. If you have driveways, the PT will be outstanding. But if you have a large, square parking lot the pickup would be my choice.
As for adapting a pickup plow to a PT425, the adapter plate is $100.00. The fittings and hoses to adapt it will probably be another $100. I don't know if the angle cylinders on the pickup plow are single or double actings, so I don't know how to plumb it. Anyway, you'd have $200 in it and it might be too heavy for the PT425 to lift well. The new PT plow is under $500.00 isn't it? Might be better off going with factory in this case.
Hope this helps and just my opinions. /forums/images/graemlins/laugh.gif
   / Will PT 60" Blade remove snow for business? #12
The Ventrac is built by the Steiner brothers who designed and built the original steiner. They are back building machines now that their non-compete is over fromthe sale of Steiner to Ransome. They have put passion and inginuity into the design and while the steiner and ventrac are essentially the same machine (the implements are interchangeable) the ventrac has several features that make it much much "newer" and operator friendly.
You're right-- the steiner is a much much better mower than the PT. But, the steiner is still not as good as a "dedicated" mower. Again the PT shines with versatility. But I believe if you're a pro lawn mower going from lawn to lawn (or like me - paying people by the hour to do it) you want speed, manuverability, and quality of cut. For that their are better machines than the PT or even the Steiner. Ditto when snow plowing, except that the steiner/ventrac is/are the best plowing machine I've ever used for residential size jobs- and I've done too much of it
As I see it most PTers on this forum use their machines as home owners where speed and productivity are less important than versatility. And those that use their machines commercially are skewed more toward the landscape business. When one compares the PT to a cut (Compact utility tractor) the PT wins hands down -- not even close. Sorry- big orange and big green. I've owned and loved your machines (CUTs) but IN MY OPINION it's still no contest. But I believe that most professional applications need speed, manuverability and quality of job more than versatility, hence IN MY OPINION the PT loses in those applications
   / Will PT 60" Blade remove snow for business? #13
Charlie
There is no one who posts on this forum that I respect more than you.
But in my opinion, plowing (not spending some time out in the driveway playing with our PTs which we all love to do! Remember, I plow professionally) but plowing with the gauge wheels on the pt designed plow is a joke. You mentioned the need to have the wheels properly adjusted. I agree. But the wheels are set for a specific pitch angle (not side to side angle) of the blade to the boom. IF this angle is changed the wheels have either no use or the blade doesn't touch the ground. And from a practical usage point of view the operator is always changing that angle because of the way the dual stick operates. The operator spends so much time finding and "tweeking" the pitch of the blade to get the wheels at the right angle/height that productivity and spacial awareness (for safety and speed) is lessened significantly. Also, every time the right/left angle of the plow is changed more adjustment needed!
There were several problems (situations I didn't like) with the rubber lip. When plowing at an angle or when using down pressure it was way too easy for the corner of the blade to gouge the driveway (very unhappy customers). Of course, if the operator takes his time and has the guage wheels set properly gouging won't happen.
Comparing the PT to the steiner for plowing is like comparing the PT to a zero turn for mowing. I still love my PT!
   / Will PT 60" Blade remove snow for business? #14
Richard:
As I said in my prior post, I have little basis for comparison in snow plowing. The 1845 is so much better than a back blade on a conventional tractor that I can declare it good. For plowing and grading, one thing I am toying with cobbling up is a tilt adapter, with a cylinder for grading but perhaps with a tilt float for snow where the gauge wheels could contribute more than they do now to keeping the blade parallel to the ground with the rubber lip touching. It does take some fiddling with angle and tilt to keep it right, which slows you down.
I certainly did not mean to suggest that the PT is a great dedicated snow moving machine, but I do think that the 425 will do fine for a bowling facility parking lot particularly if you don't let it get too deep. It may not be the fastest commercial unit out there, but it has surprising capability for a 25 hp machine. That's based primarily on reports from MossRoad, Bubenberg and other 425 operators, along with my 1845 experience. (I assume with the 1460 you have enough power and traction just to float the bucket and power through with snow streaming off both sides. I can do that with light stuff, but the wet 12"+ type stopped me when the bucket got full.)
My PT mower is a 72" rough cut. If you look at the blade experiments that John Coxon and I did, you'll see we weren't satisfied at first, and still can improve. But, it mows pastures faster and more easily than our CUTs. Now, towing a 5 foot Acrease, I can compete in speed with the smaller batwings, but for my lawn, I got an Exmark hydro 48" walk behind. I certainly agree it's a better mower, but the guys who keep the blades sharp and the height correct on the PT 425 get some pretty results too.
I doubt you and I have any disagreement at all. The Power Trac is the only machine I've owned that routinely gets the reaction: "Weren't you just mowing with that? How did you get the loader on so fast? What the hell is that thing?"
And Power Trac doesn't even mind if you weld some modification to it.
   / Will PT 60" Blade remove snow for business? #15
Charlie
We agree.
The PT is the best all around machine made
PERIOD !
Perfect-- NO!
But way ahead of what ever is in second place.
BEST
Richard
   / Will PT 60" Blade remove snow for business? #16
guys you didn't comment on my thought concerning the 2445 or 2460 if you are not going to use the PT as a mower - did anyone try out these machines just curious
   / Will PT 60" Blade remove snow for business? #17
Ed: I got the 1845 because steep slope mowing was my main objective. I never even climbed on the 2445. I hope Wasabi will chime in, because I know he likes his 2445.
   / Will PT 60" Blade remove snow for business? #18
well, i appreciate your thoughts, your liking for steiner and bigger pts .... but please don't tell me that i don't know what professional snowplowing is, unless you have been around areas like my native country and Jackson Hole (Bondurant, USA) altitudes between 3000 to 7000 feet above sea level .... where snow plowing is a way of living for up to five month out of each year.......
and yes, i would have loved to have had, a pt 425 to remove the snow out of the corners i had to remove it COMMERCIALLY.
would it not be silly if i would compare pts to a locomotives or road snowblowers that remove the snow on one of the spurs on the orient express lines or the mountain passes in the Alps .... which seems what is happening here.
and by the way quite a bit has to do with the way the operator is going about his business ... not always can you push straight .... with any size machine .... even the aforementioned locomotives, sometimes have to do more than one passage to get the job done.
right now i am making canoes so i can mow (commercially) the large properties i have not mowed for the last ten days for my acrease and pt 425
good luck with your much bigger machine which we have too but i think this is the wrong forum to talk about large tractors?!?!?!?!?!
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2019 GENIE...
2007 CATERPILLAR D5G XL CRAWLER DOZER (A52707)
2007 CATERPILLAR...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
2014 Ford F-150 Pickup Truck (A55852)
2014 Ford F-150...
2012 BOBCAT E80 EXCAVATOR (A52707)
2012 BOBCAT E80...
gravely riding mower (A53424)
gravely riding...
