Mowing Will my 110 tlb pull 12' finish mower ok?
   / Will my 110 tlb pull 12' finish mower ok? #1
mechatgsk
Wilson, NC
Kubota M7060
Hello, I was wondering what you guys think of pulling a 12 foot batwing finish mower with a 110 TLB.
Regards,
Mechatgsk
   / Will my 110 tlb pull 12' finish mower ok? #2
it should we pull a woods 12' with a jd 3720 hst
   / Will my 110 tlb pull 12' finish mower ok? #3
If you were planning to mow golf course fairways... I'd say go for it! Heavier, 4",5" or 6" grass - I wouldn't do it with my 110!
Finish mower or not; that's alot of machine to power off of 33hp. Eight foot finish mower - no problemo!
But, 10' or 12' -- I think you'd be putting more on the engine and the pto clutch than I'd consider to be sensible.
AKfish
   / Will my 110 tlb pull 12' finish mower ok? #4
I agree with AKfish, long term strain will cause problems the 110 is a 31 pto hp machine.
About the 3720, this is a much lighter machine than a 110 without the backhoe. It would need less hp to move around while mowing and would have a better chance at this.
   / Will my 110 tlb pull 12' finish mower ok? #5
Recommened PTO horsepower for a 12 foot rotary cutter, 60. I smell an expensive warranty dispute in the near future.
I am looking at the woods tbw144. I read that this mower required a minimum of 30 hp. I know my 110 has 33 pto hp and 43 engine hp according to John Deere specifications. I feel if the grass is mowed on a regular basis it should be fine according to all specifications on both pieces of equipment. Thanks for all replies!
Regards,
Mechatgsk
   / Will my 110 tlb pull 12' finish mower ok? #8
Regards,
Mechatgsk
Interested to hear your reviews of how that mower/tractor combination performs. I checked out the web link and could not find any info regarding the overall weight of the machine.
Did notice that the brochure pictures offered a 5000 series JD attached to the front...
AKfish
   / Will my 110 tlb pull 12' finish mower ok? #9
Is there any reason you NEED a 12'? I think the 8' would be a lot better for you and wouldn't have to worry about power. My $.02 anyway.
   / Will my 110 tlb pull 12' finish mower ok? #10
The TBW150C only needs 25 pto hp. 12.5 foot of cut too.
2008 Kenworth T800 Semi Tractor, VIN: 1NKDX4TX68R235070, Day Cab, Cummins ISX-600 Turbo Diesel (A59076)
2008 Kenworth T800...
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
2004 Dodge Dakota Pick Up (A55272)
2004 Dodge Dakota...
2024 Bobcat T770 (A57148)
2024 Bobcat T770...
Year: 2017 Make: Dodge Model: Grand Caravan Vehicle Type: Van Mileage: Plate: Body Type: 4 Door V... (A55758)
Year: 2017 Make...
