Will Massey MF40B cab fit on MF20D?
   / Will Massey MF40B cab fit on MF20D? #1
cullen69
Nottingham, PA
Massey MF20D
Hey guys, I have a 20D and am wondering if a 40B cab will fit on my tractor. Both have 3pts and loaders. Let me me know what you think. It appears that the loaders are close in size. I am fine with mild fabrication but I'm not trying to chop and channel too much.
Thanks in advance
   / Will Massey MF40B cab fit on MF20D? #2
I think it should fit, it may, or may not take a little fabrication.
   / Will Massey MF40B cab fit on MF20D? #3
The MF20D used different sheet metal than the 20C and 40B. Sims built the factory cab for the 40B. It is a ROPS / FOPS cab. However the same cab with minor modifications was used for the 20C, 30B, 40B, and 50C. I have not seen a 20D with a cab on this side of the Atlantic. You will most likely have to do some modifying to get it to fit.
If you post some photos of the cab, I should be able to tell if it is a Sim's. The Sims cabs bolt to the loader uprights. My 20C has the Sims cab on it. The Cab attaches in two points, the loader uprights and the axle. you will most likely have to fab new axle mounts as they were different depending on what tractor the cab was mounted to. You will also need to create some sort of adapter from the loader to the cab mount.
I think the most challenging part will be the cab floor. You will probably have to do considerable fab work on it.
Please post photos of the two and I can ID the cab.
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A53472)
Neckover GL24-2-7K...
2020 UNVERFERTH 332 LOT NUMBER 199 (A53084)
2020 UNVERFERTH...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A51694)
2008 KZ Sportsman...
FRONTIER LP2196 LOT NUMBER 113 (A53084)
FRONTIER LP2196...
2023 CATERPILLAR 279D3 SKID STEER (A51246)
2023 CATERPILLAR...
1992 Peterbilt 377 Sleeper Cab (A53472)
1992 Peterbilt 377...
