Will Massey MF40B cab fit on MF20D?
   / Will Massey MF40B cab fit on MF20D? #1
cullen69
Nottingham, PA
Massey MF20D
Hey guys, I have a 20D and am wondering if a 40B cab will fit on my tractor. Both have 3pts and loaders. Let me me know what you think. It appears that the loaders are close in size. I am fine with mild fabrication but I'm not trying to chop and channel too much.
Thanks in advance
   / Will Massey MF40B cab fit on MF20D? #2
I think it should fit, it may, or may not take a little fabrication.
   / Will Massey MF40B cab fit on MF20D? #3
The MF20D used different sheet metal than the 20C and 40B. Sims built the factory cab for the 40B. It is a ROPS / FOPS cab. However the same cab with minor modifications was used for the 20C, 30B, 40B, and 50C. I have not seen a 20D with a cab on this side of the Atlantic. You will most likely have to do some modifying to get it to fit.
If you post some photos of the cab, I should be able to tell if it is a Sim's. The Sims cabs bolt to the loader uprights. My 20C has the Sims cab on it. The Cab attaches in two points, the loader uprights and the axle. you will most likely have to fab new axle mounts as they were different depending on what tractor the cab was mounted to. You will also need to create some sort of adapter from the loader to the cab mount.
I think the most challenging part will be the cab floor. You will probably have to do considerable fab work on it.
Please post photos of the two and I can ID the cab.
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
Ford Transit Van (A52377)
Ford Transit Van...
Hyster H225E (A47384)
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
